GD88 panasonic i have panasonic gd 88 whose keypad is lock after using normal code for it which is 1 to 8 and 00000000 the phone refuse to unlock. pls i want a way out :confused: |
GD Edit Tool v3.00 Software GD Edit Tool v3.00 :D Down: http://www.panasonic.com/consumer_el..._pc_editor.asp nstall files specification: GDSetup.msi - Edit Tool Software Installation program InstMsiA.exe - Microsoft Installer Installation program InstMsiW.exe - Microsoft Installer Installation program (Unicode version) Setup.exe - Edit Tool Software startup Installation program Setup.ini - Parameters for Edit Tool Software startup Installation program install note: run the Setup.exe. restart the computer if prompted after install, otherwise some applications will not run normally. operating system: Windows2000, WindowsXP install requirement: disk 3M; RAM 32M Important Note: If you have already installed a previous version of the PC editor tool, then please uninstall the software beofore you install version 3. |
