Panasonic Panasonic-News... |
07-21-2004, 18:47 | #2 (permalink) |
Freak Poster Join Date: Dec 2000 Location: Hungary
Member: 2779 Status: Offline Thanks Meter: 5 | goldtools Unzip all the files to the same directory. Run the install program. It may take a while to pass the first bit but dont worry it hasnt crashed. Follow it through like any normal install prog. Until it asks you for 2 codes, above the 2 boxes there should be a code something like C257JT00. Write this down. Now close the install or minimize. Open the keygen, Click the scrolling bar at the top to see the options. Type in the code that you just wrote down in the ID box then press the shield. This will give you 2 codes, again write these down. Open the install program again or "maximize" it again, now enter the first code in the first box and the second in the second. Press next , now it should install the program. Copy the "Appinit1.dta" file into the installed directory. Run the "GTools20.exe" it will ask you for your 2 codes again enter the first code in box labelled code 2 and the second code in the third box. The program will then register the components TWICE! Close the program then open it up again then it should be fully installed and working. regards fido |
Need SPV E200 unlock key help me. | tianma | HTC & PDA WM( With Touchscreen) | 12 | 04-06-2012 13:23 |
How to unlock siemens A70 with mx key help me | dey mobiles | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 12-26-2009 02:34 |
C170 key help me | pvhung_huaf | Trident/AGERE Platform | 0 | 03-25-2009 02:48 |
