Panasonic Panasonic-News... |
03-03-2003, 13:42 | #1 (permalink) |
Freak Poster Join Date: Oct 2001 Location: Kiev, Ukraine Age: 46
Member: 6852 Status: Offline Thanks Meter: 4 | Panasonic Free Solution for REPAIR DEAD Phones solution for phone with BGA or no BGA chip you need : - 1 dead phone and 1 worked phone - hot air station and soldering station - PC with cable with external power - software use WinMoDo with main and language pack - microscope (optional, but recomended) Steps : - desolder from bad phone flash chip - desolder from good phone flash chip - solder in BAD phone works flash chip - connect good phone with cable to PC - run WinMoDo with GANG mode - starting upload - when you see in LCD : Flash loader - disconnect cable from phone - in display you see Flash loader and phone frezee - phone in FLASHING MODE !!!! - YOU NEED DESOLDERING FLASH CHIP FROM WORKED, POWERED AND FREEZED in flash mode PHONE !!!!!!!! CAREFULY !!!!!!!!!!!!! - DESOLDERING GOOD FLASH CHIP from BAD phone (phone still avaible in flash mode) - SOLDER BAD FLASH CHIP in BAD PHONE - PHONE STILL in FLASH MODE - connect phone with cable to computer - press OK - you see uploading process - erasing 7-10 minute and flashing - :-)) smile P.S. use Winmodo with option writing BOOT, MAIN and LP flash WARNING !!!! if you lost original flash chip , you lost eeprom area !!!!!!!!!!!! and when you solder another flash chip, repeat repair procedure and power on phone - phone no powered !!! ENJOY P.S. tested and approved by m.com - GD35, 92, 93, 95 ATTENTION!!! AUTOR TAKES NO RESPONCIBILITY FOR DAMAGED PHONES! ATTENTION!!! Contact: xxxxxxxxxxxxxxx web site:xxxxxxxxxxxxxxxxx Icq: xxxxxxxxxxxxxxxxxxxxxxx Last edited by evilspell; 03-05-2003 at 09:50. |
solution for repair dead n95 8gb after bad usb flash with jaf | Kot_Silvester | Nokia Base Band 5 ( BB-5 ) | 3 | 02-10-2009 12:57 |
Solution for repair dead Zxxx phones | MOB~Tec Uk | NSPRO | 4 | 03-17-2006 22:23 |
Is There, Or will be there a Free Solution for SEMC SE Phones | PhonePlus | Sony Ericsson | 8 | 03-28-2005 03:35 |
Any a real working solution for repair DEAD C62 | Jumanji | NON Siemens Brand (ODM Phones) | 5 | 03-05-2005 09:06 |
