Panasonic Panasonic-News... |
12-13-2004, 18:40 | #1 (permalink) |
Junior Member Join Date: Aug 2004 Age: 50
Member: 76291 Status: Offline Thanks Meter: 0 | downloader 4.2 donīt work to A100 I would like to know if this program for flash G50 really work for flash A100 because it is all certainty in relation to the files, the cable is functioning perfectly, I tested with other devices, but the program does not want to function with the A100. It is giving error as I describe to follow: ==> Agent 100% - Timeout Fail:3: Monitor Complete Afer ==> Agent 100% - Timeout Fail:6: Handshaking-Processing This method to unlock already functioned with somebody? Have some special skill to make this program to work, as the form to perhaps pressure power? I only want to know if somebody already obtained using this software or not, not to be losing time and to be able to find one another solution. Grateful, MAX |
12-17-2004, 14:20 | #6 (permalink) |
Freak Poster Join Date: Aug 2003 Location: Bulgaria Age: 45
Member: 37317 Status: Offline Thanks Meter: 8 | ok ysesterday I sucessfully flashed A100 using G50 cable and Downloader 4.2 In the very begining I had same problem here "Agent 100% - Timeout Fail:3: Monitor Complete" but after maybe twenty retries I finally got it flashed. You just need to set the connector in the right place and that's it b.r. |
12-18-2004, 12:44 | #7 (permalink) | |
Member: 76291 Status: Offline Thanks Meter: 0 | Quote:
I obtained to make the flash in the A100. The question is to make right the connector in the correct place. It is very difficult to make right this connector in the certain position, but exactly with the flash I did not obtain still to make the raising of the unlock. But he is registered that for flash the program work. mcreis | |
need g50 flash file for downloader 4.2 | tokuna7 | Panasonic | 0 | 10-21-2004 09:26 |
My Nokia 3310 Ver. 4. 18 don`t work, can someone help me with a full Flash | Mastermo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-06-2001 11:31 |
