Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Panasonic
Panasonic Panasonic-News...
Old 06-22-2003, 08:26   #1 (permalink)
Member: 24753
GD67,ËÓkeypad blocked,recieve only incoming calls
i have gd67 with blocked keypad in all times.....phone dont ask phpne code and more.on display i see operator name and key......KEYPAD LOCKED, AND PHONE RECIEVE ONLY INCOMING CALLS
help
Old 06-22-2003, 10:37   #2 (permalink)
BLIDA's Avatar
Member: 15439
Sonork: 100.43816
Thanks Meter: 52
type the good user code and it show you OK on screen , after that disable it at security menu .
Old 06-22-2003, 10:47   #3 (permalink)
Syed's Avatar
Member: 19979
Thanks Meter: 116
use CB 2000 ver 1.389 for reading user code... and put this code in your phone... ur keypad is active again
Old 06-22-2003, 17:53   #4 (permalink)
Member: 24753
SYED thx in advance
solutions on www.gsmlab.com(in protected zone)
Old 07-02-2003, 09:27   #5 (permalink)
Member: 7845
Thanks Meter: 3
of course use channel box
rest full fact
you want channel box latest vers.
cntact me icq.
1.35r
Old 07-02-2003, 09:33   #6 (permalink)
Member: 7845
Thanks Meter: 3
rest full fact
cntact me icq.
1.35r
Old 07-13-2003, 22:19   #7 (permalink)
Member: 20634
Please can some one post cb2000 here.
The refered gsmlab is can not be read in english.
Old 07-14-2003, 23:35   #8 (permalink)
Member: 34394
its ok
you can unlock & flash it by useing this software press here
Old 07-24-2003, 02:53   #9 (permalink)
Member: 11208
Thanks Meter: 11
Flashing always risky. SO just use cb2000 or cracked 2d.
That is all
Old 07-24-2003, 10:55   #10 (permalink)
kingmobilephone's Avatar
Member: 31471
Thanks Meter: 7
cb2000 can't do unlock...
crack2d does for version before A22
I am totally with u for the risk for flashing..and repairing cost!!
phones with possibility to block incoming calls .... microera Wanted Products 3 08-03-2008 18:37
Is it possible to block incoming calls and txt on the Nokia 9500? Fanchthang WD2 & APE (Symbian Phones) 5 04-22-2005 16:41
9500 incoming call or txt blocking individual numbers! HELP ! Fanchthang WD2 & APE (Symbian Phones) 0 03-07-2005 14:25
Block incoming calls on t191 Gorro Motorola ODM 0 06-24-2002 13:41
BE1 not receive incomming calls. only make outgoing calls DrMobile Alcatel & TCL Old Models 1 05-23-2002 19:19
Page generated in 0.17560 seconds with 9 queries
