Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Panasonic
Panasonic Panasonic-News...
Old 06-11-2004, 17:44   #1 (permalink)
Member: 26517
Thanks Meter: 48
X70 Keylock , Who Can Help ?
I have this phone panasonic X70 ,it has key lock .None of the key is functioning .Only send and power off key is functioning .
Any Kind Hearted gentleman can help me to remove it .I tried 0000 and 1234 but it did not worked.
My email address is [email protected]
Old 06-11-2004, 18:02   #2 (permalink)
Member: 13808
Thanks Meter: 163
hi,
check on the forum for chanel box version 1.50 CB2000 .. that you can use to remove the user code,,..
bR
Old 06-12-2004, 01:10   #3 (permalink)
Member: 7700
Thanks Meter: 28
yes you can read key code with cb2000 with fbus cable.
but how to remove service provider lock..??
i try to flash but still locked
Old 06-12-2004, 11:20   #4 (permalink)
Member: 20069
Thanks Meter: 131
Originally Posted by essojay
hi,
bR
Hi Sir,
n T191 standard cable or modified cable to use ?
thanx
Old 06-12-2004, 11:27   #5 (permalink)
Member: 13808
Thanks Meter: 163
for x70, the cable connector looked like a miniature P2K cable... its a small version of the p2k cable.. and its not T191, t191 cable connector type is for x60..
bR
Old 06-12-2004, 12:48   #6 (permalink)
ansartec's Avatar
Member: 26500
Sonork: 100.101633
Thanks Meter: 282
Yes friend Channel box will help u to solve this problem.
Read phone code and unlock it manually.
Old 06-12-2004, 13:53   #7 (permalink)
Member: 26517
Thanks Meter: 48
Could you anyone send me like for CB2000 VER 1.50.
Old 06-15-2004, 02:46   #8 (permalink)
Siemens man's Avatar
Member: 3925
Thanks Meter: 22
hi guys
where is pin out for x70????????
thank you
Old 06-18-2004, 21:07   #9 (permalink)
Member: 26517
Thanks Meter: 48
Hi everyone, i have CB2000 but i cannot read or clear security code for my X70.After selecting model 'X70' ,I clicked Handset Power but the phone never turns on .I see this erro message on the screen
failed to converge DAC 110 volts 4.720917 Iters 31
failed to open comms. to handset
It is the same cable i used on com1 to read and write log for griffin .When i connect the cable on com 1 and connect my griffin on lpt ,i read the log from phone and sent log to my supplier and my supplier send me back unlocked log i used my cable again to write to phone ,it works fine without problem .
Old 06-18-2004, 21:19   #10 (permalink)
Member: 13808
Thanks Meter: 163
when you click on handset power, you have to press phone power too.. /..
bR
Old 06-19-2004, 13:57   #11 (permalink)
Member: 26517
Thanks Meter: 48
Thanks essojay ,i have done that too but the same error message is showing
Old 06-21-2004, 01:59   #12 (permalink)
Member: 3925
Thanks Meter: 22
hi guys
tell me pin out. wich pin is use headset or charge pin??
thank you
Old 07-22-2004, 15:49   #13 (permalink)
Member: 2461
Thanks Meter: 22
Anyone got a working link to this chanel box version 1.50 CB2000
B.Rgds
John...
Old 07-22-2004, 17:57   #14 (permalink)
robinhood's Avatar
Member: 846
Thanks Meter: 31
hi
the software is ok.
open soft. go to file-setup-general-com port and select manual ,
after that u phone can be read.
regards
Old 07-22-2004, 23:36   #15 (permalink)
Member: 64313
Just press the zero key 4 times 0000 when the phone is on (stand by) and then the keylock is off, then go to menu and turn the auto key lock off
Who can help me! I want to unlock the machine is 9530, however, who can help me, it i mazeyu520 BlackBerry (RIM) 2 10-02-2009 08:39
who can help me?!!! E335 is dead,where i can download flash file or backup file? wildtiger SYSOL Platform 1 09-02-2005 05:32
Who can help to working build x70 cable sandokaan Panasonic 1 01-24-2005 14:48
Who can help me!Who can help me! ksin2004 Samsung Flashers, Software, Firmware. 1 07-31-2004 12:50
Gd 35 Keylock,who Can Help Me ? sunrise gsm Panasonic 5 06-17-2003 01:15
Page generated in 0.21640 seconds with 9 queries
