Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Panasonic
Panasonic Panasonic-News...
Old 08-27-2004, 16:24   #1 (permalink)
.::Zafar Communication::.'s Avatar
Member: 71045
Thanks Meter: 19
Panasonic GD87 dead during flashing?????
hi
to all friend
panasonic above come for unlocking i tryied on spunlock software crack to read the code give the error then i try downgrade with a29 flash file start flashing with boot and main file startworking erase complete and while writing 1 percent at boot stop working now it become dead agian all tries faild no communication with mobile complete dead any solution please
thanks & regard
Old 06-14-2005, 13:29   #2 (permalink)
Member: 41620
Hi there!
I have the same problem here right now.
First of, I tried to downgrade panasonic gd87 to "a22".
it was signalling... then it was erasing something after 1:20 minutes , so I stoped download, after this my phone TOTALY DEAD!
Please help me fix this problem, the custumer will come today.
/Regards
Old 06-14-2005, 13:35   #3 (permalink)
GsmCyber's Avatar
Member: 6080
Thanks Meter: 4
don't remove the battery... removing the battery it's the totaly kill of the phone when something fails...
Panasonic ***** to upgrades and downgrades...
Old 06-14-2005, 13:37   #4 (permalink)
Member: 41620
Unhappy
You've maybe right, but unfortunately I've already done that
So are they any solutions, or not?
/regards
Old 06-14-2005, 16:17   #5 (permalink)
Member: 7911
Thanks Meter: 7
If you killed the boot, there are basically 3 things you can do:
1) Use a JTAG programmer to restore the boot
2) Remove the flash from the PCB and manually program it with the bootstrap
3) Replace the main PCB
Yeah, this ***** - but it's one of the big problems with the Panasonics.
Old 06-14-2005, 17:31   #6 (permalink)
Member: 6358
Thanks Meter: 10
If you don't have JTAG, use another good phone to program the flash chip, procedure is described here in forum.
Old 06-14-2005, 18:14   #7 (permalink)
Member: 34809
Thanks Meter: 5
try to use win 98, or 98ME when downloading. I,ve had better results with these than XP.
If it stops, don't remove battery, just abort the flash and try again, until succesfull.
Old 06-15-2005, 11:53   #8 (permalink)
Member: 41620
Hi everyone!
@ Alberto_fiol
So you mean that I might have a chance to fix this or what?
Old 06-15-2005, 22:00   #9 (permalink)
Member: 34809
Thanks Meter: 5
if you took the battery out the solution is like
trimesh mentioned above.
Old 06-18-2005, 00:13   #10 (permalink)
opo
opo's Avatar
Member: 16350
Sonork: 110823
Thanks Meter: 42
Late but an experience after all
Boot is in flash, so if u kill phone all u need is an already programed flash. Take okflash put in dead phone. start Winmodo , check gangmode , select good com (usb unibox flash at hy speed up to 812500 -tested by me and ok). To eliminate all posible errors make enable Boot,Main, language, and now do Start Download. Program will say press ok when all units read signalize .
Forgot to mention During all processus need to have alim on PCB (personal iuse +5v from external power suply)
Now when say press ok when all units read signalize press nothing, just take off cable to Com and replace okflash with deadflash. Make pcb COOL cozz hot i don't know what will hapen. when cool reinsert COM cable and now you can press OK.. Two posibilities
1 All oki flash will go on, you will have working phone
2 Flash doesn't start a) good posibilities is that you have put flash wrong, or cold solder and there you have to restart procesus
b) flash Ic is bad...that is bad, cozz u have to find good one
After flash u have to use CB2000 and make script erase
Thats all folks
The cat
panasonic x100 dead during flashing ataiwaris Infinity-Box 8 11-16-2008 10:03
Panasonic X70 Dead During Flashing axilleask Panasonic 18 10-22-2004 19:30
Panasonic GD87 ver 53 flash file !!! DanV Panasonic 2 06-24-2004 20:53
Panasonic GD87 dead but i can flash it GazI Panasonic 7 10-29-2003 11:04
Help!!! Mars is dead during flashing... Roman Mitsubishi 1 11-27-2001 20:20
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.16696 seconds with 8 queries
