Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Panasonic
Panasonic Panasonic-News...
Old 06-18-2005, 09:46   #1 (permalink)
OLYMPIOS's Avatar
Member: 93568
Thanks Meter: 44
Looking for Adler downloader cracked?????
Hi to all i m looking for adler cracked version cause i want to flash x400
OR else software to flash x400.......???
if someone can help will be usefull...
Thanx
Old 06-18-2005, 12:41   #2 (permalink)
GSM MIND's Avatar
Member: 20645
Sonork: 100.1579175
Thanks Meter: 635
Thanx
MATE I THINK INFINITY CAN DO NEVER TESTED BUT ITS ALSO CRACKED
BEST REGARDS
GSM MIND
STAND ALONE
Old 06-18-2005, 13:08   #3 (permalink)
Bobi's Avatar
Member: 7881
Thanks Meter: 5
Here you can find original instalation of Adler flasher. There is firmware for A500, X200 & X400 too. After install replace two libraries in DLLs subfolder of flasher with attached ones.
Old 07-11-2005, 23:51   #4 (permalink)
Stoyan's Avatar
Member: 14868
Thanks Meter: 44
Opps,
but where to find bulgarian language for Adler flasher . LP14 ?
I have just in bin format. need *.cus
WBR
Old 07-12-2005, 20:05   #5 (permalink)
Bobi's Avatar
Member: 7881
Thanks Meter: 5
@Stoyan
We all need it, mate. It's a cruel world, those who have it - don't give it, those who could give it for free - don't have it.
Old 07-13-2005, 03:31   #6 (permalink)
GSM SNIPER's Avatar
Member: 27291
Thanks Meter: 81
problem in flashing X400
after have installed the soft and overwriting the DLLs ,when I run the soft in goal to flash an X400 It displays these messages :
Please help me to bypass this problem !
Old 07-13-2005, 07:23   #7 (permalink)
Bobi's Avatar
Member: 7881
Thanks Meter: 5
@bamor2002
When start program don't choose Adler Auto, but Adler only. And set COM number and speed at the bottom of screen.
Old 07-13-2005, 11:49   #8 (permalink)
GSM SNIPER's Avatar
Member: 27291
Thanks Meter: 81
Wink
@ Bobi
thanks but :
You haven't read well the screen shot (titled X400 flashing problem )
The problem is not in Spêed and and the com !
I have done all correctely !look to the screen shots (part 1 and part 2)
All is well !
Old 07-13-2005, 13:15   #9 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
I have same problem
Update
Ninja4pana_delta00134.004.dep < X60_eep134.cfg Not found! >
- In manual file select mode, the CFG files are expected to be found in the same directory as the DEP file.
I change Name "Ninja4eu_eep134.cfg ===> X60_eep134.cfg"
but Flash Stop in ~45%
anyone havne this Files or solution
Old 07-13-2005, 17:56   #10 (permalink)
Bobi's Avatar
Member: 7881
Thanks Meter: 5
Sorry, can't help. I have same problem. Flasher don't accept any other name for CFG file exept that starting with x60. And flashing stop at 43%.
Old 07-14-2005, 00:21   #11 (permalink)
Xak
Xak's Avatar
Member: 1951
Thanks Meter: 5
We have cheap original Panasonic Service dongles (DWD) in stock:
http://forum.gsmhosting.com/vbb/showthread.php?t=218927
Old 07-14-2005, 00:41   #12 (permalink)
PhantomGSM's Avatar
Member: 9719
Thanks Meter: 4
X60_eep134.cfg hmm try searching this forum harder. I remember this file being here a while ago
wbr
Old 07-14-2005, 01:03   #13 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
@daloser
thanks for Help
I search all X400 & X60 post & I download all attached files, but no result
Old 07-16-2005, 17:58   #14 (permalink)
Member: 128187
I need a software for spanish language for A100 pan
i need a spanish language software for panasonic a100.If anyone can help me .
thankyou
Old 07-17-2005, 11:20   #15 (permalink)
Stoyan's Avatar
Member: 14868
Thanks Meter: 44
So i have repaired my restarted X400 , and menaged to upload BG lang using PanaUfo cracked.
10x to all.
WBR
Looking for digimoto 5 cracked? The Repair Shop CAR Electronics 2 07-29-2009 23:56
Looking for GD75 downloader GSM SNIPER Panasonic 0 10-08-2004 12:10
looking for pkd1 or crack phoenix ! aaaabbbb Wanted Products 1 12-12-2003 17:09
Page generated in 0.23383 seconds with 10 queries
