Panasonic X70 Dead During Flashing I Was Trying To Flash The X70 To The Latest Firmware When The Power Went Down I Was Somewhere At 80 % I Have Tried To Repeat The Process But I Get Error Message I Am Using Winmodo For X70 Can Anyone Help Me Find A Solution? I Am Desparate Please Help Me :( |
If you Plug the Battery Out when the Phone is in Boot Mode, You'll LOST the boot of ur Phone same thing happen as GD87 Only Solution is Jtag :p |
only jtag because combo flash is glued are you from greece??contact me |
Excuse me friends, but to flash a X70 wtih winmodo what cable I must use? USB? Because I don't find a serial cable! Pls explain me how I can flash It! Thanks at all |
Correct cable!! Panasonic use serial powered cable,,and usb cable,,but you can flash the phone with not original usb cable...you have to install the right drivers....but all drivers is the same,,(you find in the cd with usb cable)your pc call..." prolific usb com port" if i remember well...and you can easly change the com port number(if you use XP)...and flash the phone...the battery must be full charge....is better... I have the original serial cable,,but i use without prob.usb not original one. Regards Xavien |
But flashing X70 I've need to download all files that show me from winmodo: .rff , .lpk, and customize file? Or I can use only .rff and .lpk files? P.S. What is the code to know the version of firmware present in X70 before flash? Thanks in advance! :) |
X70 You can use rff and lpk file only...sure....and to know the version power on phone with sim inside,,before that the phone get the net,press *à#9999#,waith a few second and you can see in the display all info that you need,the first line is software version regards Xavien |
X70 sorry.... *#9999# BS Xavien |
Bye |
I've try to flash X70 with winmodo but when appear "Signalling" and I push red power button, nothing!!! What I do? |
hı may be x70 repair easy use winmodo but not normall mod gang mod and you need normal workıng x 70 please contact me msn [email protected] Quote:
Cable that I have is USB only, maybe I need to change with any drivers in serial/usb cable!?!?! Help |
I've try all solutions to flash X70 with winmodo and Usb Cable, but nothing!Also in Gang Mode! Winmodo says all time: "Signalling" but when I push on Power red button not happen nothing! :( What I do? |
@maurone: go to:my computer-(right button on your mouse)-properties-hardware-device manager and check what com is your USB cable-use same com port to downloader (winmodo) for X70 |
Yes, I know this procedure! I've selected COM3 and same port for winmodo for X70 but nothing! Download don't start! |
