Panasonic Panasonic-News... |
10-04-2004, 10:12 | #1 (permalink) |
Crazy Poster Join Date: Feb 2004 Age: 53
Member: 51960 Status: Offline Thanks Meter: 0 | Panasonic X70 Dead During Flashing I Have Tried To Repeat The Process But I Get Error Message I Am Using Winmodo For X70 Can Anyone Help Me Find A Solution? I Am Desparate Please Help Me |
10-04-2004, 10:17 | #2 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | If you Plug the Battery Out when the Phone is in Boot Mode, You'll LOST the boot of ur Phone same thing happen as GD87 Only Solution is Jtag |
10-15-2004, 23:36 | #5 (permalink) |
Freak Poster Join Date: Jan 2001 Location: Malta Europe
Member: 3127 Status: Offline Sonork: 100-76993 Thanks Meter: 9 | Correct cable!! Panasonic use serial powered cable,,and usb cable,,but you can flash the phone with not original usb cable...you have to install the right drivers....but all drivers is the same,,(you find in the cd with usb cable)your pc call..." prolific usb com port" if i remember well...and you can easly change the com port number(if you use XP)...and flash the phone...the battery must be full charge....is better... I have the original serial cable,,but i use without prob.usb not original one. Regards Xavien |
10-17-2004, 02:24 | #6 (permalink) |
No Life Poster Join Date: Jul 2004 Age: 46
Member: 74084 Status: Offline Thanks Meter: 8 | But flashing X70 I've need to download all files that show me from winmodo: .rff , .lpk, and customize file? Or I can use only .rff and .lpk files? P.S. What is the code to know the version of firmware present in X70 before flash? Thanks in advance! |
10-17-2004, 03:06 | #7 (permalink) |
Member: 3127 Status: Offline Sonork: 100-76993 Thanks Meter: 9 | X70 You can use rff and lpk file only...sure....and to know the version power on phone with sim inside,,before that the phone get the net,press *à#9999#,waith a few second and you can see in the display all info that you need,the first line is software version regards Xavien |
10-18-2004, 11:57 | #11 (permalink) | |
No Life Poster Join Date: Apr 2002 Age: 48
Member: 10580 Status: Offline Thanks Meter: 43 | hı may be x70 repair easy use winmodo but not normall mod gang mod and you need normal workıng x 70 please contact me msn [email protected] Quote:
10-18-2004, 12:37 | #12 (permalink) | |
Member: 74084 Status: Offline Thanks Meter: 8 | Quote:
Cable that I have is USB only, maybe I need to change with any drivers in serial/usb cable!?!?! Help | |
10-18-2004, 19:16 | #13 (permalink) |
Member: 74084 Status: Offline Thanks Meter: 8 | I've try all solutions to flash X70 with winmodo and Usb Cable, but nothing!Also in Gang Mode! Winmodo says all time: "Signalling" but when I push on Power red button not happen nothing! What I do? |
10-18-2004, 19:45 | #14 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Greece Age: 47
Member: 26279 Status: Offline Thanks Meter: 274 | @maurone: go to:my computer-(right button on your mouse)-properties-hardware-device manager and check what com is your USB cable-use same com port to downloader (winmodo) for X70 |
panasonic x100 dead during flashing | ataiwaris | Infinity-Box | 8 | 11-16-2008 10:03 |
X70 dead during unlock | Irfangk786 | Infinity-Box | 18 | 02-13-2008 14:02 |
X70 dead during unlock. | Mr GsM | Infinity-Box | 2 | 06-17-2006 11:56 |
X70 Dead during unlocking | Gr8SightMan | Infinity-Box | 12 | 09-12-2005 09:12 |
Panasonic GD87 dead during flashing????? | .::Zafar Communication::. | Panasonic | 9 | 06-18-2005 00:13 |
