Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UFS - Pro
Old 10-04-2013, 16:51   #76 (permalink)
Member: 1819296
i have same problem and i also try all method.... i format my pc bt same problem.....
The Following User Says Thank You to saifresh For This Useful Post:
Old 10-08-2013, 23:06   #77 (permalink)
Member: 582684
Thanks Meter: 3
Originally Posted by mohyzo07 View Post
i use ufs panel to update box and reinstall 3 files ,after that i connect the soft ,its work very well;thanks for ufsx team
It worked for me. Thanks
Old 10-09-2013, 06:27   #78 (permalink)
kanokh's Avatar
Member: 1736804
Sonork: 100.1644836
Thanks Meter: 433
App: UFSx (HWK) Control Panel v 2.3.0.2 by SarasSoft
Box: 1 Location: 17 Serial: 72389
UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 7
UFS_USB V2.6 (c) SarasSoft 2005., Sn: 72389
LIC: True
None Authorised Copy of Software Detected, Reinstall
HWK: NOT AUTHORISED, Update Box
Bad IX: 1111
Failed: 102
Your IP: 114.130.65.28
Support: Bad HID, Cannot Access Suport
Something Wrong, Try to Use [Update Box]
LIC: True
REST: Ok
UFSx: UFS3 SarasSoft, USB S/N: 72389
NVML: Ok
INIT FBI Failed: 1
Old 10-10-2013, 08:27   #79 (permalink)
Member: 1063204
Sonork: mujeebbridco
''16 please reinstall support suite'' my hwk update time this error pls help me
Old 10-12-2013, 07:01   #80 (permalink)
sefo's Avatar
Member: 1356821
Thanks Meter: 85
please any one can help with this box i hase buy it from a frend hes has note use it for 3 years i have instald it under windows 7 professional 32 thanks for all help
Box: 1 Location: 0 Serial: 78983
UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10
UFS_USB V2.8 (c) SarasSoft 2007., Sn: 78983
LIC: True
Bad IX: 1111
Failed: 102
Your IP: 88.172.122.113
LIC: True
REST: Ok
UFSx: UFS3 SarasSoft, USB S/N: 78983
NVML: Ok
BOOT: UFxBoot V2.2 (c) SarasSoft 2003.
CORE: UFS_USB V2.8 (c) SarasSoft 2007.
SERN: 78983
LIC5: True
BOXK: 0
LIC: True
LIC: True
Bad IX: 1111
Failed: 102
Old 10-14-2013, 15:55   #81 (permalink)
ashish800's Avatar
Member: 1889562
Thanks Meter: 591
All hwk installtion solution here
ALL HWK ERROR DONE
(1) PLEASE REINSTAL HWK SUPPORT SUIET.
(2) ERRORE 16..
Uploaded with
NOTE:- WINDOW FORMTING ....
The Following 2 Users Say Thank You to ashish800 For This Useful Post:
Old 10-16-2013, 23:36   #82 (permalink)
sefo's Avatar
Member: 1356821
Thanks Meter: 85
mann why you guys do that so juste poste your solution hir in forum
Old 10-17-2013, 04:24   #83 (permalink)
Member: 990302
Any Body please help my box ( n-Box )
App: UFSx (HWK) Control Panel v 2.3.0.1 by SarasSoft
Box: 1 Location: 1553 Serial: 91528
Boot Id: 00 00
Box Login Failed
Bad IX: ABCD
Failed: -102
HID Number Corrupted, Try to Use [Update Box]
Boot Id: 00 00
Box Login Failed
Bad IX: ABCD
Failed: -102
Boot Id: 00 00
Box Login Failed
Fatal LOGIN Error, Need Repair Box, Contact Distributor..
how can i fixed that,,, ( need any silution ) plzzzzzzz
The Following User Says Thank You to harrycsz For This Useful Post:
Old 10-19-2013, 10:10   #84 (permalink)
Member: 1063204
Box: 1 Location: 532 Serial: 90201
UFS_USB V2.8 (c) SarasSoft 2007., Sn: 90201
LIC: True
Bad IX: 1111
Failed: 102
Your IP: 117.206.31.17
LIC: True
REST: Ok
UFSx: UFS3 SarasSoft, USB S/N: 90201
NVML: Ok
SERN: 90201
LIC5: True
BOXK: 1
LIC: True
then this error ''16 please reinstall support suite'' how to solve this pro
Old 10-20-2013, 11:17   #85 (permalink)
Member: 2045736
Sonork: winrar
error please reinstal hwk support suite.
plz.......... solution bro............ help me
Old 10-26-2013, 21:12   #86 (permalink)
Member: 1870514
uninstall ur antivirus or pause protection..
then go to UFS PANEL...
1. go to HARDWARE TAB
2. SCAN BOXES
3. CHECK BOX
4. UPDATE BOX
5. again CHECK BOX
6. go to SOFTWARE TAB
7. CHECK SEVER
8. INSTALL
***problem solved***
Old 10-27-2013, 10:44   #87 (permalink)
ashish800's Avatar
Member: 1889562
Thanks Meter: 591
(1) formating window some error solve...
(2) after formating not solve ufs error then flash ufs & hwk box.
how to flash ufs & hwk?
ans:- which coming errore. error name hwk flasher search in google.
note:- if not solve final solution all error.
(1) change hwk internal ic..
(2) hwk internal ic conect to hwk ic flasher divice with battry (its 'a usb device). and when u conect bettry flash........... buy in market.
Old 11-04-2013, 16:24   #88 (permalink)
ashish800's Avatar
Member: 1889562
Thanks Meter: 591
Old 11-04-2013, 16:27   #89 (permalink)
ashish800's Avatar
Member: 1889562
Thanks Meter: 591
hwk errore 000080 solution here
SHOW THIS EEROR BRO UPDATE UFS NEW DARIVER
UFS_USB_Driver_30830_W8 - Download - 4shared
Old 11-04-2013, 16:51   #90 (permalink)
ashish800's Avatar
Member: 1889562
Thanks Meter: 591
use oregnal instal packege errore solve..............
The Following User Says Thank You to ashish800 For This Useful Post:
Page generated in 0.41522 seconds with 8 queries
