Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UFS - Pro
Old 12-16-2013, 05:51   #16 (permalink)
Member: 1282588
Thanks Meter: 9
its is work
thanks brother it is working
Old 12-26-2013, 18:27   #17 (permalink)
Member: 1940330
Sonork: Takesure
fatal error
Originally Posted by ashish444_jse View Post
hi all,
if ur box gives error 102 & fatal ligin error try HWK RASKULATOR ur problem 1000% solved.
Thanks
thanks guys for the work.. my problem is solved now updating
Old 12-28-2013, 16:46   #18 (permalink)
PRINCE MOBILE's Avatar
Member: 449748
Thanks Meter: 162
UFS+HWK 2.3.0.3 Last Server Update 2013-12-16_ - Download - 4shared
Old 02-01-2014, 02:57   #19 (permalink)
Member: 1791252
Sonork: 100.1611326
Thanks Meter: 20
Box Login Failed
Fatal LOGIN Error, Need Repair Box, Contact Distributor
problem solve HWK REPAIR
The Following User Says Thank You to raizen23 For This Useful Post:
Old 02-01-2014, 03:09   #20 (permalink)
Member: 2108476
Sonork: 100.1614936
Thanks Meter: 7
do not try to install for 1 or 2 days, after you try to install again and you post if I run panel v2.3.0.4 updated
Old 02-04-2014, 09:14   #21 (permalink)
Member: 767677
Thanks a lot!!! It`s work for me 100%
Old 02-20-2014, 06:02   #22 (permalink)
Member: 1708451
Thumbs up hwk update problem solution
hwk fatal error problem solution
1. use ufs v 2.3.0.4 (latest version)
2. direct click update box ( do not click scan box or check box)
3. if u see box serial number click registry backup and save in ur hard drive
4. after clicking registry backup if u see update client ok and upgrade ok then
click update box.
5. if u see bad software or in the last line shows "click software page" then click scan box.
6. now go to software tab.
7. i think everithing will be ok now.
Old 03-11-2014, 08:42   #23 (permalink)
reset12345's Avatar
Member: 694652
Sonork: 100.1669706
Thanks Meter: 1,005
Originally Posted by raizen23 View Post
Box Login Failed
thanks brother my proublam solve............
Old 03-15-2014, 10:02   #24 (permalink)
Member: 2082450
Thanks Meter: 1,454
use the latest client and update ur box , ur problem will be solved.
Old 05-12-2014, 10:11   #25 (permalink)
Member: 2091907
Thanks Meter: 6
now i m trying to update but after some time appear this error
plz help
Authentication stage error: Connection Closed Gracefully. Internet connection error or server offline.
Old 05-12-2014, 11:03   #26 (permalink)
Member: 541042
Thanks Meter: 519
Read Sticky Thread by HWK
Old 05-22-2014, 22:10   #27 (permalink)
Member: 6653
Sonork: 100.1597550
Thanks Meter: 26
Thanks You! USF alive !!!
Old 07-24-2014, 14:11   #28 (permalink)
Member: 2223055
HID Number Corrupted, Try to Use [Update Box]
Old 07-25-2014, 04:37   #29 (permalink)
niceraees's Avatar
Member: 354975
Sonork: Love For All
Thanks Meter: 462
any help my hwk not updata after updating hwk err sd rapire 5 any help hwk team plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz zzzzzzzzz
Old 09-10-2014, 16:47   #30 (permalink)
Member: 835669
Thanks Meter: 7
Originally Posted by jesi aditya View Post
All For thats Problem i happen to me to....
and the solution is :
really2 working for me.
you can search and Download at 4shared
How to Use it ?
Open the Palication,Click "Connect" and you'll see your Box ID Serial.
Don't Change the serial,just Click "Write Razkalizement" until the Process finish(will finish in 5-10 second).
close the Aplication,and your box & Hwk ready to Upgrade again...
i hope this can help U all...
good job working 1000%
Page generated in 0.23823 seconds with 8 queries
