Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UFS - Pro
Old 11-15-2013, 11:39   #1 (permalink)
Gsm.zone's Avatar
Member: 1888427
Sonork: 100.1619536
Thanks Meter: 163
none authorised copy of software detected please use original install instalation too
none authorised copy of software detected please use original install instalation tool version 2.3.0.3 Higher
Last edited by Gsm.zone; 11-15-2013 at 11:41. Reason: [URL=http://imageshack.us/photo/my-images/690/1gur.jpg/][IMG]http://img690.imageshack.us/img690/6958/1gur.jpg[/IMG][/URL]
Old 11-15-2013, 12:04   #2 (permalink)
Member: 1668548
Sonork: 100.1647046
Thanks Meter: 24
1..uninstall old suit/panel,,,,,may be latest....
2..install the latest version USE Panel V 2.3.0.3
3..disable the anti virus
4....in hardware .. check the box....if shows any error donot matters ....may be
5.....update box......after it
6.....in software.....check server ...an index will open put
7....install
.....allll are up to dated
The Following 2 Users Say Thank You to rajkilotra For This Useful Post:
Old 11-24-2013, 15:54   #3 (permalink)
Member: 1708064
MAKE Update Box............ONLY
The Following User Says Thank You to benbelkassem For This Useful Post:
Old 12-02-2013, 09:14   #4 (permalink)
Registered User
Member: 740118
Thanks Meter: 7
good worked thanx just upgrade with ufs panel
Old 12-03-2013, 11:42   #5 (permalink)
Member: 1626204
Thanks Meter: 48
dont worry bro
bro i also face this problem.........but dont worry
format u pc and install windows sp3
dont install antivirus.........
and install latest ufs pane 2.3.0.3
http://forum.gsmhosting.com/vbb/f411...fs3-h-1739382/
u r problem will slove..............
The Following User Says Thank You to dinnu For This Useful Post:
Old 12-12-2013, 13:03   #6 (permalink)
Member: 964659
Thanks Meter: 2
7....install
Did all the same various time,
next day the same thing shows again
The Following User Says Thank You to tapash04073 For This Useful Post:
Old 12-12-2013, 16:12   #7 (permalink)
Member: 1934582
Thanks Meter: 6
use latest set up ur promblem solved
The Following 2 Users Say Thank You to sr.mobiles For This Useful Post:
Old 12-16-2013, 07:27   #8 (permalink)
Member: 964659
Thanks Meter: 2
what do you think I am doing???
client version 2.3.0.3 it installed software version dctxbb5 2.3.0.2
do you think more latest setup or update are available there???
Old 12-17-2013, 09:56   #9 (permalink)
Member: 1626204
Thanks Meter: 48
clean u r pc and instal windows xp3.and install latest setuo http://forum.gsmhosting.com/vbb/f411...1739382/.....u r pronlem will 1000000% slove........net speed 4mbps.....instal during at night time.bro
The Following 2 Users Say Thank You to dinnu For This Useful Post:
Old 12-22-2013, 17:04   #10 (permalink)
Member: 730611
none authorised copy of software detected, please use original instalation tools, version 2.3.0.3 or higher...
HELLO sir i did all same problem
Old 12-28-2013, 16:53   #11 (permalink)
PRINCE MOBILE's Avatar
Member: 449748
Thanks Meter: 162
UFS+HWK 2.3.0.3 Last Server Update 2013-12-16_ - Download - 4shared
Old 01-13-2014, 22:34   #12 (permalink)
Member: 1120289
Thanks Meter: 148
none authorised copy of software detected. i reinstalled clean registry always the same
Old 01-14-2014, 12:50   #13 (permalink)
Member: 1012044
Sonork: 100:1668956
Thanks Meter: 131
1..computer on
2..connect your internet
3..download UFSx_Support_Suite_Setup_v02.03.00.04
4.. dou not dis
5..
ClickUFSX Support Setup
6.. computer ufs connect
7..
UFS_USB_Driver
8..C:\Program Files\SarasSoft\UFS\UFS_USB_Driver
THANK ALL GSM FRINDS
http://forum.gsmhosting.com/vbb/f311...tions-1216246/
The Following 2 Users Say Thank You to shanjoyhalder For This Useful Post:
Old 02-07-2014, 03:24   #14 (permalink)
romeo_1's Avatar
Member: 548049
Thanks Meter: 42
i allready use all work but everyday same problem same time work same time not work. mostly update all file but none autorise copy of software. what is this. very bad
The Following User Says Thank You to romeo_1 For This Useful Post:
Old 02-07-2014, 07:13   #15 (permalink)
Registered User
Member: 740118
Thanks Meter: 7
if you box use with bb5 best flasher after update with ufs panel dont use again with bb5best flasher.
i
Sent from my iPhone using Tapatalk
Page generated in 0.18996 seconds with 8 queries
