Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UFS - Pro
Old 04-25-2011, 08:45   #16 (permalink)
Member: 1504915
Sonork: 100.1641606
its working no problam
Old 04-25-2011, 13:36   #17 (permalink)
amn32's Avatar
Member: 569925
Sonork: 100.1624057
Thanks Meter: 6,313
Server is working fine.
Log report .
Upgrade log:
---------- HWK Update Client v 2.1.0.0 ----------
---------- HWK upgrade started:4/25/2011 2:15:34 PM ----------
-- Target Id : xxxxxxxx
-- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003.
-- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007.
-- UFSx S/N : vxvvvvvvvvvv
-- Features : 00000001
-- Licence 5 : True
-- UFSx Vendor: TORNADO
-- HWK ID : A1.04-PRO1-xxxxxxxxxxx
-- HWK Status : 1, DL: 0
Locating HWK Upgrade server...
HWK Upgrade server found!
Preparing connection to server...
Connecting to HWKUpgrade server...
Server connection successfully established.
Authenticating on server...
Authentication successfull.
Checking upgrade client version...
Your upgrade client is up-to-date.
Upgrading HWK...
HWK upgrade process completed.
---------- HWK upgrade finished:2:15:50 PM ----------
Old 04-26-2011, 12:38   #18 (permalink)
Member: 1502539
Thanks Meter: 41
hwk upgred setup site
1st Setup:HWK_Support_Suite_Setup_v02.10.000
(Note): HWK_Support_Suite_Setup_v02.10.000 then start HWK upgrade to finish. then setup step by step below under check.
2nd Setup:
HWK_Suite_Setup_v02.10.000
3rd setup:
HWK_Suite_Minor_v02.10.001
4th setup:
HWK_Suite_Minor_v02.10.002
5th setup:
HWK_Suite_Minor_v02.10.003
6th setup:
HWK_Suite_Minor_v02.10.004
The Following User Says Thank You to memonarif For This Useful Post:
Old 05-19-2011, 01:40   #19 (permalink)
Member: 586472
Thanks Meter: 6
sir need help my hwk error
-- UFSx Device: UFS3 SarasSoft, USB S/N: 38442
-- Target Id : 62 CF 1 10
-- UFSx S/N : 38442
-- Licence 5 : True
-- HWK NOT CONNECTED or DEAD
-- HWK ERROR : 0010
The Following User Says Thank You to jhonrie For This Useful Post:
Old 05-26-2011, 17:49   #20 (permalink)
Member: 1584831
Thanks Meter: 46
hwk update failed
i have also same problem ,
unable to update.if any one have perfect solution share with us......
The Following User Says Thank You to ashish.srk2 For This Useful Post:
Old 05-26-2011, 18:10   #21 (permalink)
Member: 646340
Thanks Meter: 15
2nd Setup:
Mr-jhonrie
you nead repair hwk your hwk is damag
Old 05-27-2011, 05:37   #22 (permalink)
Member: 1555845
Sonork: 100.1604818
Thanks Meter: 4
-- UFSx S/N : 38442
-- Licence 5 : True
-- HWK ERROR : 0010
Sir 1ST REMOVE OLD INSTALLSION AND RESTART PC AND 2ST INSTALL NEW HWK UPDATE AND UPDATE HWK 90% WORK TRY AND POST
Old 05-27-2011, 07:28   #23 (permalink)
Member: 1562047
Sonork: cas'per
-- UFSx S/N : 38442
-- Licence 5 : True
-- HWK ERROR : 0010
tolong gan hwk punyaq ...Authenticating on server... Authentication stage error: Error: Server returned unrecognized reply.
Old 05-27-2011, 07:36   #24 (permalink)
Member: 361348
Thanks Meter: 635
i think u must use new version hwk update client
Old 05-27-2011, 07:40   #25 (permalink)
Member: 1068814
Sonork: 100.1584449
Thanks Meter: 10
Upgrade log:
---------- HWK Update Client v 2.2.0.0 ----------
---------- HWK upgrade started:5/26/2011 6:21:53 PM ----------
-- UFSx S/N : 00000
-- Licence 5 : True
-- HWK ID : A1.04-PRO1-4636A64D01270075
Upgrading HWK...
---------- HWK upgrade finished:6:22:08 PM ----------
Old 05-27-2011, 07:48   #26 (permalink)
Arshu007's Avatar
Member: 1476028
Sonork: 100.1625985
Thanks Meter: 114
UFS HWK Update SUCCESS .........
Upgrade log:
---------- HWK upgrade started:5/27/2011 12:15:12 PM ----------
-- UFSx S/N : 12345
-- Licence 5 : True
-- HWK ID : A1.04-PRO1-12121212121212A
Upgrading HWK...
---------- HWK upgrade finished:12:15:23 PM ----------
The Following User Says Thank You to Arshu007 For This Useful Post:
Old 05-27-2011, 08:17   #27 (permalink)
Member: 1434428
Sonork: nonunikku18
Upgrade log:
---------- HWK upgrade started:5/26/2011 10:45:10 AM ----------
-- UFSx S/N : 99585
-- Licence 5 : True
-- UFSx Vendor: TWISTER
-- HWK ID : A1.04-PRO1-FB4D5529002700C8
Connection to server failed: Socket Error # 10060
Connection timed out.(A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.)
this is my problem pls help me..................
Old 05-27-2011, 08:27   #28 (permalink)
Member: 1434428
Sonork: nonunikku18
Unhappy
Originally Posted by nonunikku18 View Post
Upgrade log:
-- UFSx S/N : 99585
-- Licence 5 : True
The Following User Says Thank You to nonunikku18 For This Useful Post:
Old 05-27-2011, 10:31   #29 (permalink)
yuresh's Avatar
Member: 1235816
Thanks Meter: 95
download support suite setup v2 HWK_Support_Suite_Setup_v02.02.000 - 4shared.com download free
update your hwk
The Following 2 Users Say Thank You to yuresh For This Useful Post:
Old 05-27-2011, 20:59   #30 (permalink)
Member: 1248310
Sonork: 100.1641641
Thanks Meter: 7
Upgrade log:
---------- HWK upgrade started:5/24/2011 5:51:33 PM ----------
-- UFSx S/N : 1234567
-- Licence 5 : True
-- HWK ID : A1.04-PRO1-E36A276543600050
Upgrading HWK...
---------- HWK upgrade finished:5:51:55 PM ----------
The Following 2 Users Say Thank You to AWASTHI TELECOM For This Useful Post:
6110 Software Change/Upgrade??? Prodigal Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-17-2000 08:33
How to upgrade firmware on Nokia Pepek Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-18-2000 23:29
Upgrade 5110 to 6110? tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-28-1999 19:59
Page generated in 0.26252 seconds with 10 queries
