07-19-2007, 14:38 | #136 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Inside facebook Age: 47
Member: 250468 Status: Offline Sonork: 100.110362 Thanks Meter: 96 | About your microscope, you need also to have advanced skills in software using. After you buy this tool, you need to download last version of AMCAP (just use google), set pin filter to resolution 800x600 to get a good picture cause zoom function is not working anymore (tested and confirmed). After uncheck all auto settings, try manual settings for picture, open lens with the key, then activate 60hz if your video card allow you. Dont foget to save you settings cause you will need to reaload anytime when you restart software. I did my 1st 6280 after doing all this settings. |
07-19-2007, 15:01 | #137 (permalink) |
No Life Poster Join Date: Sep 2001 Location: GSM-TOOL Age: 52
Member: 6328 Status: Offline Thanks Meter: 3,595 | For me it was working directly with the software and drivers that was comming with the microscope. If i would have experienced the same problems like you, then i could have searched for the solution also. However, i am happy that it is now working also for you, because that is most important... regards, Gobi P.S. Your description will help us in future to solve similar problems with customers. Thx for the feedback |
07-19-2007, 19:28 | #138 (permalink) | |
Banned Join Date: Oct 1999 Age: 55
Member: 563 Status: Offline Thanks Meter: 22,328 | Quote:
http:///vbb/showpo...4&postcount=18 | |
07-19-2007, 20:22 | #139 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Szczecin, Poland Age: 44
Member: 10350 Status: Offline Thanks Meter: 68 | Hi Using this stereoscopic microscope you will gain the same results: It has 40x zoom. It`s tested here in Poland with BB5 unlocking and reparing other phones... I dont say that your one is not good - but it`s nothing special instead it has same name as infrared station which is very popular in GSM lastly Br Jakub |
07-19-2007, 21:52 | #141 (permalink) | |
Member: 6328 Status: Offline Thanks Meter: 3,595 | Quote:
I am curious, now that the customer (actually not even my own direct customer) has found out what was in his particular case the problem, and could use the microscope --> what other "problem" you will invent to the TORNADO DEVICES ... boah, ... such a looser ... ratatule | |
07-20-2007, 09:55 | #142 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Back to GSM from AV
Member: 325999 Status: Offline Thanks Meter: 113 | Dear Sir What Is The Temprature For Prehiter When Removing 3230 Flex & What Time Its Take To Remove The Flex. Regards Last edited by Raheeeeb; 07-25-2007 at 22:36. |
07-20-2007, 10:16 | #143 (permalink) | |
Product Supporter Join Date: May 2001
Member: 4566 Status: Offline Sonork: 100.112355 Thanks Meter: 503 | Quote:
regards, ren | |
07-21-2007, 15:59 | #144 (permalink) | |
Thanks for the information. As we selling this kind of tools expects that all who do BB5 testpoint unlocking has enough knowledge on both software and hardware. This box worths around €2000 - €6000, plus the price of each phone it unlocks which is normally high end models. It has big risks, so a qualified pro unlocker is highly recommended to do the task. Happy unlocking. regards, ren | |
07-25-2007, 09:45 | #145 (permalink) |
Junior Member Join Date: Jan 2005 Age: 42
Member: 111576 Status: Offline Thanks Meter: 0 | hi, i just purchase tornado infra handheld from one of reseller in indonesia, i've question to ask mr gobi or mr ren: 1. how much exactly temp that it work to pick up connector, glued ic?coz last time i pick up the batt connector, the tornado damage the connector(e.x. in dct4+ board like 1110,1600,etc) 2. i only purchase the handheld without the preheater, does it mean so much for the result?can i combine it with lukey preheater? thx for the answer P.S. the temp that i use is 30.65! |
07-25-2007, 09:52 | #146 (permalink) |
07-25-2007, 10:14 | #147 (permalink) | |
@candra_yus For the battery connector, you should put some good flux to decrease the melting point, and set the temperature to around 30 on your handheld station. Too much temperature can burn the pcb, so start from low first. For glued ic and lead free PCB's, a preheater is a must. This is to preheat the pcb first with temperature around 100 degrees C before you rework using the the handheld station. More practice on how to use it can achieve better results. For more technical info's you can contact or pm me here. regards, ren | |
07-25-2007, 10:54 | #148 (permalink) |
Member: 325999 Status: Offline Thanks Meter: 113 | [quote=ren77;2599603]@candra_yus For the battery connector, you should put some good flux to decrease the melting point, and set the temperature to around 30 on your handheld station. Too much temperature can burn the pcb, so start from low first. For glued ic and lead free PCB's, a preheater is a must. This is to preheat the pcb first with temperature around 100 degrees C before you rework using the the handheld station. More practice on how to use it can achieve better results. For more technical info's you can contact or pm me here WHAT KIND OF FLUX WE NEED TO USE (WHICH BRAND IS GOOD FOR MOBILE REPAIR) REGARDS |
07-25-2007, 11:35 | #149 (permalink) | |
Member: 4566 Status: Offline Sonork: 100.112355 Thanks Meter: 503 | [QUOTE=neo_49;2599701] Quote:
There is a flux (lead free) included in the package specially made for tornado infra for better results. Picture: regards, ren | |
07-25-2007, 12:35 | #150 (permalink) | |
regards, ren | |
**********: CE Certification for Tornado Infra Stations !!! | Gobi | Tornado Infra Station | 10 | 08-22-2009 08:27 |
What is Tornado Infra Station ? | Gobi | Tornado Infra Station | 0 | 07-26-2007 19:05 |
@tornado Infra Station Needed In Topic @ | chiragp | Off Topic Zone | 1 | 06-05-2007 12:53 |
