06-03-2007, 06:04 | #62 (permalink) |
Junior Member Join Date: Apr 2007 Location: infra planet
Member: 488313 Status: Offline Thanks Meter: 0 | hi |
06-03-2007, 12:46 | #64 (permalink) |
No Life Poster Join Date: May 2004 Location: A ROUGH ROAD LEADS 2 THE STARS
Member: 66937 Status: Offline Thanks Meter: 5,053 | |
06-04-2007, 04:20 | #65 (permalink) |
No Life Poster Join Date: Mar 2003 Location: china Age: 44
Member: 24934 Status: Offline Thanks Meter: 0 | Aoyue968.aoyue808,aoyue738 hello,friends, we can offer the repair tools for you. The brand of repair tools we have is AOYUE series: AOYUE 968; AOYUE 808;AOYUE738.... we can offer you the best price and soupport. We are dedicated to offering you exclusive, innovative and quality poducts at affordable prices. Whatever products or services you are looking for, Taurus Electronics strive to offer it. If you are interested, pls do not hesitate to contact us. you can visit us at: www.gsm-taurus.com msn/email ID: [email protected] Best regards Ran |
06-04-2007, 09:23 | #66 (permalink) | |
Junior Member Join Date: May 2007
Member: 513415 Status: Offline Thanks Meter: 0 | Quote:
How many machines have you bought and tested already? DO they fail you? If failed, whats the failure? I can see that you are so mad on this product, can you tell us whats wrong with it? You may use it for a while and take a look at its performance. Then if it fails you, come back here and tell us whats really wrong with it. br, | |
06-06-2007, 19:34 | #68 (permalink) |
No Life Poster Join Date: Sep 2001 Location: GSM-TOOL Age: 52
Member: 6328 Status: Offline Thanks Meter: 3,595 | It is same usefull like a Hotair station that don't melt your plastic connectors, don't **** your components away from the pcb and heat only the tracks on the flexes, without burning the rest. You can even remoove metal shields with it by raising the power-temperature level from the Potentiometer - but be carefull to go back to normal power- temperature when returning to normal PCB work -- else it can even heat up to 900 degree Celsius the PCB and tost it . Also you can use the Tip on the heater - to do more delicate work, like working on flexes. At the end the Tool offers everything needed to do the job, but the repairer still need to have the necessary skills for the job - since hardware don't have 1 button press-solutions. Usefull enaugh for you ? regards, Gobi |
06-07-2007, 03:45 | #70 (permalink) |
Member: 6328 Status: Offline Thanks Meter: 3,595 | http://www.tornadoinfra.com/eng/videos You see there videos, most made by our beta-testers and customers - some using also the preheater, and some only the handheld. regards, Gobi |
06-07-2007, 04:13 | #71 (permalink) |
No Life Poster Join Date: Aug 2005 Location: singapore Age: 55
Member: 173565 Status: Offline Thanks Meter: 71 | ok ,video 4 n 5 are infrared without preheat .For sure a longer time to remove or replace . Question you should advice ppl put on protective gears while using your products . It will cause skill cell n eyeball to breakup ,you know what I means ? Here I attention user ,use gloves n goggles . |
06-07-2007, 14:11 | #72 (permalink) |
Member: 6328 Status: Offline Thanks Meter: 3,595 | According to the Infra -heater producer there is no need for googles - so far you don't stay looking alltime into the heater. A laser pointer for the keychain is more dangerous for the eyes as this element, if you compare ... The reflection comming back from the pcb is not dangerous. As sayed - the operator should not look directly into the heating element for longer time and not stay with his eyes few centimeter away from the element. But if somebody wants google - then any plastic-lens googles are ok - no need for any special material. regards, Gobi |
06-10-2007, 23:22 | #74 (permalink) |
Member: 6328 Status: Offline Thanks Meter: 3,595 | The infrared heater is ceramic, and not a bulb. The lifetime, according to the manufacturer is over 3000 hours. This means in a normal usage - about more then 1 year !!! The replacement cost at this moment is still high, since the heater is custom-made, but will decrease fast in parallel with the rising nr of units in production. regards, Gobi |
06-17-2007, 16:50 | #75 (permalink) | |
Member: 66937 Status: Offline Thanks Meter: 5,053 | Quote:
Many Handset Of Motorola An Samsung Handset Repair Sucessfully... Before It Was Not Possible To Remove Glue Ic's An Led Free Ic's...(Due To Board Damage) But After Using Tornado Infra This Become Very Easy...!! 1. Removing Uem Appox 40 Sec Without Any Damage...!! 2. Samsung Flex Connecter's In 10 Sec Without Damage...!! 3. Removing Any Board Connecter 15 Sec Without Damage..!! 4. Removing Sim Ic Display ic Keypad ic Crystel's Led Free P.A (P.f)..!! 5. Removing Display With Flex 30 Sec...! 6. Tested On Many CDMA Handset....!! Nokia Samsung Kyosera L.G Most Important You Can Re-Use All Connecter Again....!!! Tornado Infra Have Unbelievable Result's.....!!! All I Can Say It's Need Of Every Hardware Person. Most Impo It's handHeld So Do Not wait Contact Your Nearest Distributer For Live Demo & Price Big Thanks To Tornado Infra Team For Making It Easy To Use...!!! Regards Munna Bhai Last edited by GsmMunna; 06-17-2007 at 18:40. | |
**********: CE Certification for Tornado Infra Stations !!! | Gobi | Tornado Infra Station | 10 | 08-22-2009 08:27 |
What is Tornado Infra Station ? | Gobi | Tornado Infra Station | 0 | 07-26-2007 19:05 |
@tornado Infra Station Needed In Topic @ | chiragp | Off Topic Zone | 1 | 06-05-2007 12:53 |
