07-25-2007, 12:04 | #1 (permalink) |
Junior Member Join Date: Jan 2005 Age: 42
Member: 111576 Status: Offline Thanks Meter: 0 | Power sourse is working, but the handel is not heating |
07-25-2007, 15:25 | #2 (permalink) | |
No Life Poster Join Date: Sep 2001 Location: GSM-TOOL Age: 52
Member: 6328 Status: Offline Thanks Meter: 3,595 | Quote:
Pls check with ren for that problem. 2-nd. Please read the atached pdf document to get a better idea how to use the tool. http://www.gsm-tool.com/Infrabasics.pdf Also - FIRST take some time and old -bad pcb and play with the infra station on them, untill you get the practical skills to use it on the phones. Then you will see all ok. Here as example the mail text i have received from one customer: "I have Tornado infra station bayed from You before mont and half ago. At first time was hardly working with it, but after same time and trening this device is working verry well and it is very good tool .................................................. ........................" regards, Gobi regards, Gobi | |
07-26-2007, 06:54 | #3 (permalink) | |
Registered User Join Date: May 2005 Location: Indonesia
Member: 147656 Status: Offline Thanks Meter: 4 | Quote:
I will help u to solve ur problem, chat by Yahoo ok? or send me back to me, as I am ur reseller (in Indonesia) Thanks br anang scpgsm | |
07-27-2007, 16:16 | #7 (permalink) |
Product Supporter Join Date: May 2001
Member: 4566 Status: Offline Sonork: 100.112355 Thanks Meter: 503 | Please contact your reseller regarding your tornado infra, and also please pm me more info about your problem. regards, ren Last edited by ren77; 07-27-2007 at 16:42. |
07-28-2007, 12:03 | #8 (permalink) |
Member: 6328 Status: Offline Thanks Meter: 3,595 | Hi I had also 1 of this warranty cases. So - the small problem is now identified: On few pieces, INSIDE THE HANDEL, 1 of the 2 connectors that connects the wires from the Heating element to the siliconic-cable was not crimped well. Jost use a crimp tool to fix that and all will be ok. However, before you open the handel, please ask your reseller if he allows it, or he repair it for you, so you don't void the warranty. regards, Gobi |
07-28-2007, 12:14 | #9 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2005 Location: U S A / GOA /CHINA Age: 44
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | @gobi as some time in black module one register breaks [near the winding coil]or weak in solder ,just open the cover and make solder if the owner is professional and can find that may he can make solder [will post the jpg soon] thanks |
07-28-2007, 12:54 | #10 (permalink) | |
That was the first pieces Infra Tool, and for this the powersupply was replaced with a different - a lighter one Most probably the customer have one of this new hardware releases, and also i am 99% sure that his problem is the one i have described in the post before. regards, Gobi | |
07-28-2007, 13:50 | #12 (permalink) |
Member: 6328 Status: Offline Thanks Meter: 3,595 | I think this kind of small problems can happen allmost everywhere on manual assembly lines, like not putting enaugh power on a crimping tool And also there was only few pieces having this contact loose ... regards, Gobi |
E 630 no key pads is working but power button | beneto | Samsung Hardware Repair | 1 | 03-28-2008 18:15 |
1600 earpace and headphone is working but ringer is not working | zargar322 | Nokia Hardware & Hardware Repair | 3 | 05-29-2007 23:35 |
HWK KZF not work... but the HWK SAMSUNG and NOKIA working... | mappology | HWK | 16 | 01-12-2006 08:37 |
Unlock code is working but the phone is still locked!!! | The Beast | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-23-2005 20:35 |
I Have T100 Every Thing Is Working But Phone Is Not Connecting Call | OSSIE | VLSI, Conexant, Skyworks and Old Models | 3 | 05-16-2003 19:52 |
