Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM > Tornado Infra Station
Old 05-19-2010, 00:37   #1 (permalink)
Member: 606522
Question What is the distance for soldering a charging port on a Blackberry
what is the distance should I keep if I want weldering a charging parts on a Blackberry mainboard? It looks the temperature is alway not high enough.
Thank you.
Old 05-19-2010, 01:32   #2 (permalink)
alexlaboratory's Avatar
Member: 771230
Thanks Meter: 773
Wink
start 380 and slowly increse to 480.....but if you sleep in it you will cook everything
Old 05-19-2010, 01:33   #3 (permalink)
Member: 771230
Thanks Meter: 773
also if you using those cheap crap china made solder station, well good luck to ya!
crank it to maximim juice 680 degrees
the trick is start with less temperature it's call the pre-heat
Old 05-19-2010, 14:18   #4 (permalink)
Member: 1306261
Thanks Meter: 2
It appears all the soldering staions on the market are made in China anyway.
So which other ones are you refering to?
Old 05-19-2010, 20:55   #5 (permalink)
Dave.W's Avatar
Member: 7653
Thanks Meter: 823
In my experience, its better to use soldering iron for replacing charging ports. Hot air is only useful in removing the old part.
Always remember to use some nice flux, it will make your work 100% easier.
Good luck.
Old 05-22-2010, 00:32   #6 (permalink)
Member: 771230
Thanks Meter: 773
Angry
Good luck.
Mr.Moderator.......in blackbarry u ain't got space to stick your solder iron, plus you can't heat enough to the ground parts of the socket......only hot air you can use for this case and you must heat from opposite side of board and nothing gets damage
when you became a real technician or have real some hardware experience, key word "real" then post.
br
Alex
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
Page generated in 0.17190 seconds with 9 queries
