Tornado TP Microscope Tips And Tricks - Please Read !!! NR1 - The product description: NEW: Tornado TP Microscope!!! Special for BB5 Unlocking !!! - Use it to make TP on BB5 Unlocking process. - So, it is a microscope FOR visualising TESTPOINTS, in particulary BB5 TP. NR2: The device looks like this: http://www.gsm-tool.com/mposter.jpg Nr3: The captured immage looks like this: http://www.gsm-tool.com/6280.jpg ALL THE CAPTURED PICTURES where made by myself and are the real pictures , as obtained from the camera. This is what is described and this is what the tool can do! MOST IMPORTANT: FOR 6280: It is VERRY IMPORTANT TO MAKE THE RIGHT ADJUSTMENTS EXACTLY IN THE ORDER I TELL YOU, else you will not be able to use the microscope. 1 - Bring the microscope-CAMERA more NEAR the PCB - about 2cm (adjustment is avaiable for this) 2 - Use the atached imbus key to unblock the Optical part and FOCUS FROM THERE After you focus -> Block that adjustment back with the imbus key 3 - Use the 2-nd adjustment of the optical part of the microscope in order to get a good picture. 4- You have also a SCALE button in the software in order to "zoom" more 5 - Verry important is also to make the setups in the software like in the 2 atached pictures, in order to get a good image without delays. (screenshots provided by one of our customers) http:///vbb/showpo...8&postcount=14 If all is ok, you will get the IMAGE, as you see here: http://www.gsm-tool.com/6280.jpg regards, Gobi |
how i can buy it i.m in egypt |
You May Find Your Nearest Reseller Here.. http://www.tornadoinfra.com/eng/class/partners Regards Munna Bhai |
i used tornado infra. can someone give me trick how to make the pict more clear. very difficult to measure . |
what About N80 the most Hard TP there should be Spcial Glue with this Set .. Please Advice |
About the special glue or is it glue remover??? we don't have it for now. We will look into this if its possible. |
what is price for this nice mikroscope ? |
could any one give me the driver for this microscope .... please |
Driver for Tornado microscope: http://www.megaupload.com/?d=MH9H7REC |
mates please anyone can explain properly how to get it more clear? Am getting it clear but ambient light then makes it unclear. have to cover the sides to get it clear again but i feel its not enough clear to make TP. would appreciate some help pls thanks |
2 Attachment(s) It is VERRY IMPORTANT TO MAKE THE RIGHT ADJUSTMENTS EXACTLY IN THE ORDER I TELL YOU, else you will not be able to use the microscope. 1 - Bring the microscope-CAMERA more NEAR the PCB - about 2cm (adjustment is avaiable for this) 2 - Use the atached imbus key to unblock the Optical part and FOCUS FROM THERE After you focus -> Block that adjustment back with the imbus key 3 - Use the 2-nd adjustment of the optical part of the microscope in order to get a good picture. 4- You have also a SCALE button in the software in order to "zoom" more 5 - Verry important is also to make the setups in the software like in the 2 atached pictures, in order to get a good image without delays. (screenshots provided by one of our customers) If all is ok, you will get the IMAGE, as you see here: http://www.gsm-tool.com/6280.jpg regards, Gobi |
How many time zoom does this microscope have?? Regards GFI Team |
