Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Scout
Old 04-10-2013, 00:50   #1 (permalink)
Member: 859004
Thanks Meter: 10
Arrow Help v.2.11
Help, I had installed version 2.10 and download the 2.11, but now when you open the program I get a window "error bliblioteca flashes", how I can solve this problem? and install several different versions from 2.0 and still the same problem, please help
Old 04-10-2013, 19:58   #2 (permalink)
Member: 859004
Thanks Meter: 10
Exclamation
Please Team Scout. help กกกก
Old 04-15-2013, 09:42   #3 (permalink)
GSM_Support's Avatar
Member: 121052
Sonork: 100.107126
Thanks Meter: 81,008
@ celulitico,
In order to solve issue you're dealing with perform following operations:
  1. Uninstall SCout flasher
  2. Manually delete SCout file folder from your PC (x:\Program Files\GsmServer\)
  3. Install SCout flasher once again
  4. Issue you're dealing with suppose to be solved.
Best Regards
GSMServer team
The Following User Says Thank You to GSM_Support For This Useful Post:
Old 04-17-2013, 01:45   #4 (permalink)
Member: 859004
Thanks Meter: 10
Arrow Solved
Originally Posted by GSM_Support View Post
@ celulitico,
Best Regards
GSMServer team
Thank you very much, problem solved.
Greetings
Page generated in 0.12922 seconds with 8 queries
