Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Scout
Old 01-08-2013, 14:42   #1 (permalink)
Member: 175183
Sonork: 0
Thanks Meter: 120
Motorola A953 cant exit from "S Flash OMAP3630" state
Hi.
I receive a "dead" phone Motorola A953 and flash with many flash files but phone dont power on.
When click power button phone and connect to computer Scout show Model "S Flash OMAP3630".
Any way to repair this phone? My customer try to update software, and dont have water or crash damages.
Maybe other flash or can i try to update Bootloader to 70.13 ?
Here Scout log from last trying:
Warning: Android in flash mode
User confirmation for flashing received
SCout 2.10. Flashing phone "S Flash OMAP3630" - "ERROR,NOT FOUND!"
flex "ERROR,NOT FOUND!" boot 70.12
with firmware "MILA2_U6_3.12.0_SIGNED_US1SMILESTONE2RETBRB125LA016.0R_GSXMILETRETBRLA_P026_A009_M012_HWp2a_Service1FF_Brasil_Retail_Android_2.2.pcf" A953(A953) - "MILA2_U6_3.12.0" - "umts_milestone2-user 2.2 MILA2_U6_3.12.0 87603249 ota-rel-keys,release-keys"
Loading file "MILA2_U6_3.12.0_SIGNED_US1SMILESTONE2RETBRB125LA016.0R_GSXMILETRETBRLA_P026_A009_M012_HWp2a_Service1FF_Brasil_Retail_Android_2.2.pcf"... OK
Preparing firmware image...
Loading RAM downloader for bootloader...
Jumping to downloader...
Erasing flash memory...
Erase completed!
Flashing code group 31...
Code group 31 flashed
Flashing code group 32...
Code group 32 flashed
Flashing code group 33...
Code group 33 flashed
Flashing code group 34...
Code group 34 flashed
Flashing code group 35...
Code group 35 flashed
Flashing code group 39...
Code group 39 flashed
Flashing code group 40...
Code group 40 flashed
Flashing code group 42...
Code group 42 flashed
Flashing code group 45...
Code group 45 flashed
Flashing code group 47...
Code group 47 flashed
Flashing code group 53...
Code group 53 flashed
Flashing code group 61...
Code group 61 flashed
Flashing code group 64...
Code group 64 flashed
Flashing code group 65...
Code group 65 flashed
Flashing code group 66...
Code group 66 flashed
Verifying checksums...
Code group 31 checksums match
Code group 32 checksums match
Code group 33 checksums match
Code group 34 checksums match
Code group 35 checksums match
Code group 39 checksums match
Code group 40 checksums match
Code group 42 checksums match
Code group 45 checksums match
Code group 47 checksums match
Code group 61 checksums match
Code group 64 checksums match
Code group 65 checksums match
Code group 66 checksums match
Phone is being rebooted...
Flash completed successfully
Old 01-08-2013, 15:34   #2 (permalink)
GSM_Support's Avatar
Member: 121052
Sonork: 100.107126
Thanks Meter: 81,009
@ gsm_unlock2,
What information is signed at the sticker under the battery of the phone?
Best Regards
GSMServer team
Old 01-08-2013, 19:00   #3 (permalink)
Member: 175183
Sonork: 0
Thanks Meter: 120
Hi.
Here information on stick.
Old 01-09-2013, 08:55   #4 (permalink)
mcandre's Avatar
Member: 239548
Thanks Meter: 2,787
I can suggest you making hard reset on this phone. Sometimes it helps. Here is the procedure
Old 01-09-2013, 15:11   #5 (permalink)
Member: 175183
Sonork: 0
Thanks Meter: 120
Thanks for reply, but i cant enter in recovery menu, i insert battery holding X button and nothing happens only black screen.
I know lcd and ribbon are ok coz when flashing phone show information on screen.
Old 02-02-2013, 17:53   #6 (permalink)
Member: 1207809
Hi I have a problem with the same A953 cell death, or the Scout In rsdlite I flash at the end of the flash appears that everything was OK, but do not power on, I insert the A953 the computer appears as "S Flash OMAP3630". You had progress? I need help. thanx
"Sorry my English is very bad."
Old 02-04-2013, 09:45   #7 (permalink)
mcandre's Avatar
Member: 239548
Thanks Meter: 2,787
Usually, once you've made flashing with the same or higher firmware version, make hard reset.
Old 02-18-2013, 12:40   #8 (permalink)
Member: 426664
Sonork: 100.109026
Thanks Meter: 25
I have the same problem, please someone know how i made this mobile turn on again?
Old 02-19-2013, 08:52   #9 (permalink)
Member: 121052
Sonork: 100.107126
@ renatoextrema,
Please provide us with more details on the issue you're dealing with.
What is current phone state?
What had happened to the set so it got to such state?
What operations you've already tried to perform?
Best Regards
GSMServer team
Old 05-18-2013, 17:20   #10 (permalink)
Member: 87188
Thanks Meter: 231
What is the file to be applied?
Have you downloaded 5GB A953 pcf files but none good:
SCout 2.11. Flashing phone "S Flash OMAP3630" - "ERROR,NOT FOUND!"
flex "ERROR,NOT FOUND!" boot 70.13
with firmware "MILS2_U6_2.4.24_SIGNED_UCAMILESTONE2B1B80E100E.0R _USXMILE20RTDACH_P021_A011_HWp2a_Service1FF.pcf" MotoA953(A953Blur) - "MILS2_U6_2.4.24" - "umts_milestone2-user 2.2.2 MILS2_U6_2.4.24 8483028 ota-rel-keys,release-keys"
Loading file "MILS2_U6_2.4.24_SIGNED_UCAMILESTONE2B1B80E100E.0R _USXMILE20RTDACH_P021_A011_HWp2a_Service1FF.pcf".. . OK
Erase completed!
Error verifying code group 32 - checksums mismatch
Error verifying code group 33 - checksums mismatch
Error verifying code group 35 - checksums mismatch
Error verifying code group 39 - checksums mismatch
Error verifying code group 40 - checksums mismatch
Error verifying code group 45 - checksums mismatch
Error verifying code group 47 - checksums mismatch
Error verifying code group 66 - checksums mismatch
Flash failed
(The phone was worked, and it was new phone, I just wanted to update)
Help please!
Old 05-19-2013, 11:54   #11 (permalink)
Member: 87188
Thanks Meter: 231
The next morning suddenly started:-O
Maybe HW fault?
We have not touched a view that's for sure!
Phone model MILESTONE2 A953
Hardware SJUG5975AA
imei 352784041479729
Technology UMTS
System
Firmware config GAS_ASIA_USXMILE20ASIARET_P029
Baseband EPU93ST2_U_03.0C.01
Baseband config UCAMILESTONE2B1B80E100E.0R (unlocked)
Build number umts_milestone2-user 2.2 MILS2_U6_2.4.18 862241 ota-rel-keys,release-keys
The problem is solved.
(although I do not know to what)
Page generated in 0.16263 seconds with 9 queries
