Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Scout
Old 03-29-2013, 15:12   #1 (permalink)
Member: 1092799
Sonork: 100.1603347
Thanks Meter: 111
motorola mb501 stuck on bootloader usb init..... after flashing
pls help me otherwise customer will kill me
pls help
thanks
Old 03-30-2013, 07:13   #2 (permalink)
Member: 1092799
Sonork: 100.1603347
Thanks Meter: 111
pls help
thanks
one day has been passed no response from some of the product supporter
thanks
Old 03-30-2013, 07:26   #3 (permalink)
nikhil_gsm's Avatar
Member: 47627
Sonork: 100.1596335
Thanks Meter: 124
http://forum.gsmhosting.com/vbb/f417...korea-1406705/
http://forum.gsmhosting.com/vbb/f417...oblem-1332417/
check this out , may help to solve your problem .
regard
nikhil_gsm .
Old 03-30-2013, 08:17   #4 (permalink)
Member: 1092799
Sonork: 100.1603347
Thanks Meter: 111
regard
nikhil_gsm .
need hair version to flash that is not in support area
thanks
Old 03-30-2013, 18:21   #5 (permalink)
Member: 1092799
Sonork: 100.1603347
Thanks Meter: 111
as per ur suggestion i flashed the phone with every firmware exist in support area but same result??????
nitin_9868494350_007: OK
nitin_9868494350_007: MOTO-W-MB501-0510(B)
nitin_9868494350_007: IS THIS SUFFICIENT??????/
Sclip Sclip: is there any branding on the phone?
nitin_9868494350_007: NO
Sclip Sclip: try flashing the phone with the secure-MB501_0.12.11_1.32.20-super*******-customer.pcf
nitin_9868494350_007: HELLO SIR FLASHED THE PHONE
nitin_9868494350_007: secure-MB501_0.12.11_1.32.20-super*******-customer.pcf
nitin_9868494350_007: BUT SAME RESULT
nitin_9868494350_007: NOW WHAT TO DO NEXT????????
Sclip Sclip: try to use 0.12.196 version
Old 04-01-2013, 13:09   #6 (permalink)
GSM_Support's Avatar
Member: 121052
Sonork: 100.107126
Thanks Meter: 81,009
@ ******aj007,
For most of Android based phone models main reason for such an issue appears because phones is getting flashed with wrong firmware versions.
Unfortunately, for this case original firmware version is "unknown" as it wasn't checked before flashing. In case if initial phone's firmware version wasn't checked before flashing handset, it is getting quite hard to revive phone.
What is current phone state and what firmware versions exactly did you use for the flashing purposes?
Best Regards
GSMServer team
Old 04-02-2013, 11:45   #7 (permalink)
Member: 1092799
Sonork: 100.1603347
Thanks Meter: 111
Originally Posted by GSM_Support View Post
@ ******aj007,
Best Regards
GSMServer team
now i have done flashing with each n every file in support area
n the set is in same condition bootloader usb init.
now u want to know about phone status that now set is stuck on bootloader usb init.
thanks
Old 04-04-2013, 06:52   #8 (permalink)
Member: 1092799
Sonork: 100.1603347
Thanks Meter: 111
stilll no support?????????????
what to do??????
Old 04-15-2013, 08:49   #9 (permalink)
mcandre's Avatar
Member: 239548
Thanks Meter: 2,787
If you flash the phone with the same or higher fw version, it don't die.
In most cases Motorola Androids die due to flashing with wrong flash files.
Try making hard reset after flashing.
Page generated in 0.16474 seconds with 8 queries
