Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Scout
Old 09-07-2012, 09:00   #1 (permalink)
Member: 64823
Thanks Meter: 440
V9 Cannot FLASH - Now Stuck on bootloader !
Procedure:
SCout 2.03. Flashing phone "S Flash Argon" - "R2633131-AS_U_A0.05.20R1"
flex "USEMERALD2100ORH3GAUS3R2633131014" boot 7.90
with firmware "R2633131-AS_U_A0.05.20R_PDS001_LP0024_DRM2001_VSTU_302_0c10 _JPJAVA_U_A0_R2633131_05_01_03R_.sbf"
Preparing firmware image...
Loading RAM downloader for bootloader...
Jumping to downloader...
Erasing flash memory...
Error erasing subscriber unit. Device API Error: 0xE00200A7 Command: ERASE
Flash failed
Information :
Phone model
IMEI
Technology
User code
Security code
Firmware R2633131-AS_U_A0.05.20R1
Flex version USEMERALD2100ORH3GAUS3R2633131014
Language pack
Bootloader 7.90
See the attached Picture !
Old 09-07-2012, 12:13   #2 (permalink)
GSM_Support's Avatar
Member: 121052
Sonork: 100.107126
Thanks Meter: 81,009
@ zakiyyboss,
According to the log file the set is connected in a flash mode.
What is wrong with the phone?
Why you're trying to flash it with the *.sbf flash file?
Best Regards
GSMServer team
Old 09-07-2012, 13:19   #3 (permalink)
mcandre's Avatar
Member: 239548
Thanks Meter: 2,787
R2633131-AS_U_A0.05.20R1_PDS002_LP0055_DRM2001_VSTU_302_0c_ JPJAVA_U_A0_R2633131-ASDI_07_02_06R_USEMERALD2100ORH3GAUS3R2633131014_W IG118705_1FF_3_Aust_locked.pcf
According to the information you posted, this is the right flash file for your phone. Please use it and next time don't downgrade your version!
Because these are two different versions:
Old 09-07-2012, 18:10   #4 (permalink)
Member: 64823
Thanks Meter: 440
Originally Posted by GSM_Support View Post
@ zakiyyboss,
Best Regards
GSMServer team
i have only sbf file. My bootloader account has longtime over. So i find it useless to activate an account for oneyear that i will use one or two time a year ! Any solution for that !!
Old 09-07-2012, 18:11   #5 (permalink)
Member: 64823
Thanks Meter: 440
Bro if i was downgrading the SAFE flashing would have STOP me ? Correct me if am wrong ! because i try other Flash file but the SAFE option refuse to flash it !!
Old 09-08-2012, 08:41   #6 (permalink)
Member: 121052
Sonork: 100.107126
@ zakiyyboss,
You can use Free Bonus Access, in case you haven't used it already.
If it was already used you can check, list of available price plans by visiting this page.
Notice that there are shorter then one year activations.
Best Regards
GSMServer team
Old 09-08-2012, 08:52   #7 (permalink)
Member: 64823
Thanks Meter: 440
@ zakiyyboss,
Best Regards
GSMServer team
Thank you very much. But are you sure its a problem of the flash file ! If i get the flash file will the phone be OK?
Old 09-08-2012, 11:49   #8 (permalink)
Member: 121052
Sonork: 100.107126
@ zakiyyboss,
In case if problem is software it suppose to be resolved by the flashing operation.
Best Regards
GSMServer team
Page generated in 0.16026 seconds with 9 queries
