![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2008 Location: Brazil Age: 42
Member: 700706 Status: Offline Sonork: 100.1590381 Thanks Meter: 208 | Xt300 Boot FF.FF which version of firmware should I use? this unit there is the motorola android xt300, and is connected in boot mode (alt + USB Cable) every 10 phones of those who come here nine died, only one worked ... and do not want to kill more phones ... what do you suggest me? |
![]() | #2 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2006 Location: Central Europe Age: 40
Member: 239548 Status: Offline Thanks Meter: 2,787 | First of all update Scout to the latest version. Then try to connect this phone in normal mode. You must know original firmware version before flashing. |
![]() | #3 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 81,009 | @ Bruno Rafael, First of all need to check what firmware version the phone/device has before performing any operation to it. Then after original firmware version is known you can select what flash file to be used. Best Regards GSMServer team ![]() |
![]() | #5 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 81,009 | @ Bruno Rafael, Check what information is signed at the sticker under the battery of the phone. Best Regards GSMServer team ![]() |
![]() | #8 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 81,009 | @ Bruno Rafael, Do you know what had happened to the phone so it getting restart in the logo? In most cases such issues can be resolved with the Master Reset/Wipe Data operations. But in some cases users are trying to update/flash some non-official firmware versions and it becomes almost impossible to restore phone to it's initial state without knowledge of what exactly had happened to the set. Best Regards GSMServer team ![]() |
![]() | #9 (permalink) | |
Member: 700706 Status: Offline Sonork: 100.1590381 Thanks Meter: 208 | Quote:
![]() | #10 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 81,009 | @ Bruno Rafael, Did you try to perform Master Reset operation already? If no, perform following steps: Hard reset through button combination:
And then it will restore back to its original factory default settings again. After that post results here. Best Regards GSMServer team ![]() |
![]() | #11 (permalink) |
Member: 239548 Status: Offline Thanks Meter: 2,787 | So you say that the phone was bricked and you tried to revive it. As far as I can see, you live in Brazil. I would use this version: SESLA_U3_01.72.0 - this version if for Brazil region, it isn't locked and without operator customizations. This is the latest version available for Brazilian XT300. These versions SESGC_U3_00.35.0, SESGC_U3_10.10.0 are for Chinese market. Last edited by mcandre; 06-19-2012 at 13:16. |
![]() | #12 (permalink) | |
@mcandre I'll try | |
![]() | #15 (permalink) |
Member: 700706 Status: Offline Sonork: 100.1590381 Thanks Meter: 208 | Sorry .. but I was so angry that the log is not saved! ![]() Now I hold the ALT key and put the usb cable and does not enter in boot mode ...... |
8810 & 8210 Phone NOT respond! (Load Boot data) | AboAli | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-25-2001 14:47 |
F_loaders.bin and Boot.bin .. . | micklong | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-29-2001 14:49 |
Phone not respond! (Load boot data) Need a help ! | SashaM | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 01-23-2001 02:10 |
Phone dont respond ( boot count ) | galles | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-31-2000 01:53 |
3210 5,36 dont show anything in the screen and EE FF!! | makona | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-09-2000 07:28 |
