Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Multi-Box TEAM Products > Multi-Box
Old 11-24-2007, 13:09   #1 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
Arrow 24-11-2007 Long time waiting update. language pack editor for Chinese phones released
24-11-2007
New update again!
New Language pack editor v.1.0 released - new universal tool which allow you to manage languages in Chinese phones MTK based phones.
Now you can add new language, remove language, also can edit exist languages.
Please go to Support files and download new software Tools, flash files.
Here I will make a discription of our new tool.
So what you can do with new editor:
- edit exissting languages in a phone
- can remove language from phone
- can add new langusge to phone
- automatic translate via dictionary
- create your own dictionary
- can save your own project
- supported all MTK based phones
- easy in use
How to add new language to phone.
For example I am using Narnia I-70 phone.
1. We need to make back up from our phone first before using soft. In the case if something will be wrong you can always restore you phone back using your back up.
Run Chinese cocktail tool ( latest version always ). Connect phone to special socket.
Press "Connect" botton and press power on botton on phone.
See attach:
( always check if info readed from phone is correct and full )
Go to backup/restore bookmark
And press "backup all flash" botton.
Now you have time a little untill backup will be readed.
So now you have working back up from you phone. Save it please.
2. Now we need to close Chinese cocktail tool and need to open new tool: MTK_LPEditor ( always use latest version. )
See attach:
Now we need to open firmware for phone which we like to edit.
IMPORTANT: NOT a BACKUP file! We need to open a firmware for our phone. All firmwares you can find at support area. You must be sure that you are using correct flash file for you phone. In my case I have Narnia I-70 phone - so I have to go to support area and download this firmware from support.
In the case if you have new model or new firmware version - you need to send your backup files readed before to: [email protected] for upgrade.
Our next step we need to open firmware for our phone. Press "new project" botton and select our flash file.
You will see next:
- How many lang inside firmware ( in our case 3 )
So now we need to add new language ( russian for example I used )
We need to press "add language botton"
In empty field we need feel them like I did
Next step we need remove 1 or 2 languages which we don't need.
IMPORTANT: If you adding new language you need always remove one of existing which you dont need!
Press "remove language" botton and select which one you don't need. In my case I removed all chinese langs.
So now we have only 2 langs. English and russian.
Next our step.
Select English lang in left menu ( is easy to use english for translating to other lang in our case to russian ) - now you can manage right side and you can translate your self it your self.
See attach:
In the case if you have dictionary you need to press botton "translate using dictionary". We have english to russian dictionary, so a pressed this botton.
And select file:
See attach:
Software automaticly start looking in a firmware phrases and compare them with phrases in our dict. If software find it - it will automaticly translate to other lang ( in our case to russian )
Now you need to check right side ( russian in our case ) if you have all phrases translated. In the case if not all are translated - you need to translate by your self the rest.
After translating all and checking you can save your new-updated dictionary for future using.
Next step we need to save our new language into firmware.
Press "Upload language pack to firmware" botton.
- first software will ask you about source file ( that mean you need choose your firmware file - same as you select at the beggining )
- second you need to choose name for new file. In my case I write same name but with "rus" adding.
Done. Now we have one more firmware but with English and russian only inside.
Our next step:
We need to run again Chinese Cocktail tool ( latest version always ).
Than conect again your phone to box and press "connect" botton.
Than select your new firmware ( which we make before ), press "eeprom" botton and than "update firmware".
It will take some time untill your phone will be reflashed.
After falshing you need disconect your phone. Reconnect battery and power on the phone.
You have now new language!
IMPORTANT:
- in the case if after flashing you have some error in log, that mean you choose wrong flash file - use back up for restoring phone.
- in the case if your phone not working after flasing - use back up for recovering.
- this is first release just - so the can be some bugs - inform us about them and we will fix them ASAP
_________________
GSMtricks - Multi-box TEAM
Old 11-24-2007, 18:27   #2 (permalink)
domidelcourt's Avatar
Member: 162067
Thanks Meter: 118
little problem with download Language pack editor v.1.0
avast has detected a virus
what do i do ?
thanks
Old 11-24-2007, 19:17   #3 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
what do i do ?
thanks
We post too many times - we use themida for packing soft and some antyvisrus this is visus inside, but on the true here is nothing. If you will use search botton you will find a lot of same topics.
Old 11-24-2007, 20:58   #4 (permalink)
Irfangk786's Avatar
Member: 146630
Thanks Meter: 21
thanx for new update always best tool
Old 11-24-2007, 23:09   #5 (permalink)
Nesirliler's Avatar
Member: 104393
Thanks Meter: 13
Wow multi box team keep it up evry time
Old 11-26-2007, 15:33   #6 (permalink)
Member: 543586
Thanks Meter: 10
hi, can I use language pack editor if using different box device, please need some advices.
Old 11-26-2007, 15:47   #7 (permalink)
Member: 327309
Sonork: 100.54567
Thanks Meter: 177
What do you mean? What different box device?
Old 11-26-2007, 15:50   #8 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
You can use only with Multi-box or Multi-box LITE
Old 11-27-2007, 05:25   #9 (permalink)
Member: 543586
Thanks Meter: 10
I meant, can I use language editor pack via others box such as Universal Box, Doctor box, mtk box, etc?
Old 11-27-2007, 10:18   #10 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
Sure cannot. This is Multi-box Team section and all softs here works only with our products.
Old 11-27-2007, 15:24   #11 (permalink)
Member: 20069
Thanks Meter: 130
Mind-****ing Update & Important one also... i think fine enough for earn some more more n more $$$ from this wonderful update.
Boy O Boy
what to say more ??? only can say Chinese fone's work realy better thn BB5 unlocking
Big Thanks to Multi-Box Team for their Hard work.
with
........Best Regards
the_frightener
Multi-Box uSeR
Old 01-05-2008, 15:46   #12 (permalink)
akhil_bbsr's Avatar
Member: 271478
Sonork: 1590868
Thanks Meter: 1,055
i have a ques**** for multi box team can u add hindi resonal language for indian costmers
Old 01-05-2008, 16:15   #13 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
Add where please?
you need dictionary for chinese phones or you want menu in soft?
Update! - MT62xx CPU Language Pack Editor for Infinity Box v1.24 s.Mobi Infinity-Box 5 01-20-2009 01:14
18-12-2007 Very GOOD very HOT, LONG time waiting update! FIRST in the WORLS w/o logs GSMtricks Multi-Box 66 05-31-2008 12:39
18-12-2007 Very GOOD very HOT, LONG time waiting update! GSMtricks Multi-box LITE 3 12-20-2007 07:35
24-11-2007 Long time waiting update. language pack editor for Chinese phones released GSMtricks Chinese Cocktail 28 11-26-2007 21:31
24-11-2007 Long time waiting update. language pack editor for Chinese phones released GSMtricks Multi-box LITE 0 11-24-2007 13:08
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.23237 seconds with 9 queries
