10-27-2006, 13:11 | #1 (permalink) |
Freak Poster Join Date: May 2005 Age: 54
Member: 145807 Status: Offline Thanks Meter: 4 | unlocking motorola c261 Please press power ON button... Syncronization with MCU OK... MCU ID read OK... Sending loader signature... Loader signature accepted... Sending loader... Loader accepted... Syncronization with loader... Syncronization with loader OK... FlashMode Active... Loader initialization... Reading loader revision... Checking firmware signature... Reading EEPROM 0x29 block subsidy lock state... SPI initialization... Loader initialization OK... Multi-Box - (c)2005 DELOK Research lab. - www.multi-box.net Unlocking phone... Nothnig for Unlock... Unlock phone error... Multi-Box - (c)2005 DELOK Research lab. - www.multi-box.net Disconnected. |
10-27-2006, 13:13 | #2 (permalink) |
No Life Poster Join Date: Mar 2001 Age: 44
Member: 3610 Status: Offline Sonork: 100.54638 Thanks Meter: 1,652 | some hints about ODM: - C115/C116/C117/C118/C139 - for this phones you need cable witch 5V TTL - C155/C156/V170/V171 - for this phones you need cable witch 3.2V TTL (but also work witch 5V) - C267/C261/V175/V176 - for this phones you need cable 3.2V only.(work very good witch Telewey USB unibox) so from begin almost 80% problem - comunication problem about unlocking new compal phones like C257 C261 etc - this phones based on CPU from TI (http://ti.com/) Secure Calipso all this phones have: - HARDWARE RSA bultin on CPU - unique MCU id - all block in eeprom like securety block, band block, battary block - RSA signed also RSA signed flash (you cant make patch) way used for unlock - curently only one way for this phones .... if you have good and 100% working cable and cant unlock this phone - this mean this phone can't be unlocked !!! |
10-27-2006, 14:53 | #3 (permalink) | |
Member: 145807 Status: Offline Thanks Meter: 4 | Quote:
WERE CAN IGET THIS CABLES? | |
12-26-2006, 16:03 | #5 (permalink) |
No Life Poster Join Date: Mar 2005 Location: United Arab Emirates Age: 43
Member: 130244 Status: Offline Sonork: 100.1609062 Thanks Meter: 143 | Entring FlashMode... Please press power ON button... Syncronization with MCU OK... MCU ID read OK... Sending loader signature... Loader signature accepted... Sending loader... Loader accepted... Syncronization with loader... Syncronization with loader OK... FlashMode Active... Loader initialization... Reading loader revision... Checking firmware signature... Reading EEPROM 0x29 block subsidy lock state... SPI initialization... Loader initialization OK... Multi-Box - (c)2005 DELOK Research lab. - www.multi-box.net Unlocking phone... 0x29 BLock unknow state... Unlock phone error... Multi-Box - (c)2005 DELOK Research lab. - www.multi-box.net Disconnected... wt is this error |
12-27-2006, 11:16 | #6 (permalink) | |
Member: 3610 Status: Offline Sonork: 100.54638 Thanks Meter: 1,652 | Quote:
- C115/C116/C117/C118/C139 - for this phones you need cable witch 5V TTL - C155/C156/V170/V171 - for this phones you need cable witch 3.2V TTL (but also work witch 5V) - C267/C261/V175/V176 - for this phones you need cable 3.2V only.(work very good witch Telewey USB unibox) so from begin almost 80% problem - comunication problem about unlocking new compal phones like C257 C261 etc - this phones based on CPU from TI (http://ti.com/) Secure Calipso all this phones have: - HARDWARE RSA bultin on CPU - unique MCU id - all block in eeprom like securety block, band block, battary block - RSA signed also RSA signed flash (you cant make patch) way used for unlock - curently only one way for this phones .... if you have good and 100% working cable and cant unlock this phone - this mean this phone can't be unlocked !!! | |
12-27-2006, 16:44 | #7 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Canada Age: 44
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | freind i have 3 C261 from french all unlocked without any problem but fro 2 C261 have same error phone can't be unlocked or what ? i can flash it ? !! Entring FlashMode... Please press power ON button... Syncronization with MCU OK... MCU ID read OK... Sending loader signature... Loader signature accepted... Sending loader... Loader accepted... Syncronization with loader... Syncronization with loader OK... FlashMode Active... Loader initialization... Reading loader revision... Checking firmware signature... Reading EEPROM 0x29 block subsidy lock state... SPI initialization... Loader initialization OK... |
12-27-2006, 16:50 | #8 (permalink) | |
01-05-2007, 09:44 | #10 (permalink) |
Freak Poster Join Date: Dec 2003 Age: 52
Member: 47532 Status: Offline Thanks Meter: 18 | how to connect to c261 n v172 coz i try a lot of times cant get connected ,i use the panasonic x60 cable .or any 1 can teach me step by step ,wat button to press on the box? |
@Infinity-Team Problem Unlocking Motorola C261 | imran_qasim | Infinity-Box | 1 | 09-06-2006 16:40 |
Unlocking Motorola C261 via IMEI without a cable possible? | torsten36ger | Phone Unlocking Codes & Maps | 6 | 07-27-2006 09:32 |
Are there a simple code for entering and unlocking Motorola C261? | torsten36ger | Motorola P2k | 4 | 07-17-2006 20:40 |
I can't unlock Motorola C261 | aplauz | Multi-Box | 11 | 07-03-2006 19:25 |
