Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Multi-Box TEAM Products > Multi-box LITE
Old 01-11-2008, 07:23   #1 (permalink)
ricson's Avatar
Member: 18329
Thanks Meter: 144
e100 unlock done but still lock
Press ON ... OK
Loading Flashloader in RAM ... OK
Flash ID: 017E0A
Read locks OK
Backup Saved To File: C:\Program Files\Multibox\ALC_Tool\BackUp\E100X_2ASAPH1_35964 7001695134__1242007_11538.bck
Write locks OK
Phone Unlocked!
Disconnected
what could be solution
phone still lock
Old 01-11-2008, 07:27   #2 (permalink)
sygnal's Avatar
Member: 235471
Thanks Meter: 57
probably a BIG BUG hmmm..... support team where are you....
Old 01-11-2008, 09:17   #3 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
You phone has sim lock or phone lock? There no bugs.
Old 01-11-2008, 09:45   #4 (permalink)
ricson's Avatar
Member: 18329
Thanks Meter: 144
need to unlock it but when sincard is inserted it ask for phone code
is there any way to reset phone code wihtout flashing
Old 01-11-2008, 10:13   #5 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
is goot to check first what software can do. Soft can di sim lock - not a phone lock. For reset phone code just use: ###847#
Old 01-11-2008, 10:45   #6 (permalink)
ricson's Avatar
Member: 18329
Thanks Meter: 144
already done reset code phone lock remove
but now still unlock done phone still as for nck code
and already check that multi box lite can unlock phone
Old 01-11-2008, 10:55   #7 (permalink)
sygnal's Avatar
Member: 235471
Thanks Meter: 57
told you there's a bug...
Old 01-11-2008, 11:19   #8 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
Ther eno bug. But the problem is that you not read docs how to use soft. Read codes and enter what is the problem????
Old 01-11-2008, 12:34   #9 (permalink)
ricson's Avatar
Member: 18329
Thanks Meter: 144
when i try to read codes this message appear
reset code should be used after entering bad unlock code for to many tries
Old 01-11-2008, 12:56   #10 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
http://www.multi-box.net/faq_article.php?article=75 read this
Old 01-11-2008, 17:36   #11 (permalink)
ricson's Avatar
Member: 18329
Thanks Meter: 144
already read it before i post my problem
the problem is there is no nck code or reset that should appear
and when i try direct unlock still the same
will just try to flash phone and post result tomorrow
Old 01-12-2008, 03:35   #12 (permalink)
sygnal's Avatar
Member: 235471
Thanks Meter: 57
come on bro look at your board problems are everywere... dont tell us that most of your users dont know how to read why dont you put a sticky instead.. Title BUGS REPORT HERE maybe a good idea believe mo s that all will post there...
brgds...
P.S.
nothing agaist just want it to be better for all of us...
Old 01-12-2008, 09:31   #13 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
brgds...
P.S.
This topic is not made by you. You don't have this phone I dont why you talking about problem.
Old 01-12-2008, 09:32   #14 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
1. Read full flash back up and send to use - maybe is new version
2. Try to reflash it with files from support!
Old 01-13-2008, 02:36   #15 (permalink)
sygnal's Avatar
Member: 235471
Thanks Meter: 57
well then il make my own tread hope tht will not deleted as always... many post are missing... accepting mistakes will make it better for all of us...
where here to help and support...
brgds...
e900 unlock done but still locked gsmservices NSPRO 5 03-16-2009 17:20
Samsung T429 Unlock Done But Still Locked Miftahudin NSPRO 4 10-30-2008 10:09
my150 unlock done but still locked Umair Rashid FuriousGold 4 09-01-2008 17:06
zte A36 unlock done but still locked tolski Infinity-Box 8 05-29-2008 14:57
th4 can't with polar and with vygis cracked, unlock done but still locked!! .:bono:. BF, BG, TH, BHx Series 5 11-07-2005 07:49
Page generated in 0.20151 seconds with 9 queries
