03-27-2009, 19:29 | #1 (permalink) |
Junior Member Join Date: Jan 2009
Member: 945133 Status: Offline Thanks Meter: 2 | 8800 sirocco rm-165 problem Hire is log 27:03:2009 17:38 -> Searching for default location of ini... 27:03:2009 17:38 -> Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-165\ 27:03:2009 17:38 -> Scanning ini files... 27:03:2009 17:38 -> Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-165\ 27:03:2009 17:38 -> FILES SET FOR FLASHING: 27:03:2009 17:38 -> MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-165\rm16511004.200 27:03:2009 17:38 -> PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-165\rm16511004.20c 27:03:2009 17:38 -> CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-165\rm16511004.20.image_c_se 27:03:2009 17:38 -> ADSP Flash file: NONE 27:03:2009 17:38 -> APE Variant file: NONE 27:03:2009 17:38 -> APE User Flash file: NONE 27:03:2009 17:38 -> Languages in ppm: English,German,French,Italian,Dutch,Spanish,Turkis h,Portuguese 27:03:2009 17:38 -> MCU: 27:03:2009 17:38 -> C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-165\rm16511004.20027:03:2009 17:38 -> 27:03:2009 17:38 -> Booting phone... 27:03:2009 17:38 -> Phone didn't answer with TX line high after UEM reset! Causes: 1. BSI line is not connected properly in connector -> Check cable, also for 3.3k resistor in serial with bsi line. 2.UEM damaged -> replace UEM. 27:03:2009 17:38 -> MCU ID: 0xCCCC 27:03:2009 17:38 -> This MCU ID is not supported in chosen flash file... 27:03:2009 17:38 -> Error booting phone... 27:03:2009 17:38 -> MCU: 27:03:2009 17:38 -> C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-165\rm16511004.20027:03:2009 17:38 -> 27:03:2009 17:38 -> Booting phone... 27:03:2009 17:38 -> MCU ID: 0x2051 27:03:2009 17:38 -> BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia 27:03:2009 17:38 -> Loader version: 04.46.0127:03:2009 17:38 -> -> Revision: 0007 27:03:2009 17:38 -> Boot size is 0x2398 27:03:2009 17:38 -> Boot is ready... 27:03:2009 17:38 -> FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 27:03:2009 17:38 -> FLASH ID1: 003000EC <=> SAMSUNG (SEC) -> K5W1G13ACB Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 27:03:2009 17:38 -> FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 27:03:2009 17:38 -> FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 27:03:2009 17:38 -> First 16 bytes: 27:03:2009 17:38 -> FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 27:03:2009 17:38 -> Flash ID is 0x22E800EC 27:03:2009 17:38 -> Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia 27:03:2009 17:38 -> Loader version: 04.46.0127:03:2009 17:38 -> -> Revision: 0007 27:03:2009 17:38 -> Loader size is 0x84A0; Loader chk: 6c 27:03:2009 17:39 -> Error Loading loader! 27:03:2009 17:39 -> FAILED Hardware problem? Always the same error |
10-15-2013, 14:25 | #2 (permalink) |
No Life Poster Join Date: May 2003 Location: POLAND
Member: 27761 Status: Offline Thanks Meter: 55 | hi which cable di you used? i tried ufc cable nr 6 same as for nokia 5000/1616-2/100 etc.. 8800 rm-13/rm-165 pinout: it's same pinout as 1616-2: but mxkey or jaf can't read this 8800 scirocco RM-165 |
Nokia 8800 sirocco rm-165 problem with flash | mopikkk | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 03-27-2009 19:42 |
Need Flash with Spanish Language for Nokia 8800 Sirocco RM 165 | Grupo MovilFree | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 03-18-2008 12:41 |
8800 sirocco rm-165 black screen after full erase and flash !!!! | gsmnice | JAF Xtras | 3 | 10-17-2007 14:37 |
Nokia 8800d Sirocco Rm-165 | SoftSkiner | Nokia Digital Core Technology 4 ( DCT-4 ) | 9 | 05-14-2007 13:44 |
8800 sorocco rm-165 | LOUMEH | Nokia Base Band 5 ( BB-5 ) | 1 | 09-18-2006 12:46 |
