Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > J.A.F - Just Another Flasher > J.A.F. By Jafsupport.com
Old 03-04-2009, 15:27   #1 (permalink)
Member: 254086
Thanks Meter: 24
My nokia n 70 is dead how to flash it
sir my nokia n70 is dead when i try to flash with jaf i can see no movement in phone but when i m trying manual flash i cant get crt bck up n crt i can boot in jaf i can get chk but i cant get info its not powering its showing powering failed so is there any solution sir pls give any way to sholw this problem .ok thank u in adavance
Old 03-04-2009, 18:15   #2 (permalink)
jafsupport.com's Avatar
Member: 125
Sonork: 100.100000
Thanks Meter: 1,305
Arrow
Try Manual Flash and make the Phone alive first... You can uncheck the CRT backup option and try...
Thanks!
Old 03-04-2009, 18:19   #3 (permalink)
Miftah_Lutfi's Avatar
Member: 638396
Sonork: 100.1615405
Thanks Meter: 170
Flash use Latest version first...,
Old 03-04-2009, 18:21   #4 (permalink)
Member: 125
Sonork: 100.100000
Thanks Meter: 1,305
Yes Ofcourse you have to use the latest version...
Thanks!
Old 03-05-2009, 20:49   #5 (permalink)
Member: 254086
Thanks Meter: 24
which version is latast for n70
sir i have version 13.somthing which i had use for flash can i have right version so i will download and then try to flash it . ok
Thank for giving advise
Old 03-05-2009, 20:59   #6 (permalink)
Member: 125
Sonork: 100.100000
Thanks Meter: 1,305
I think Dpv 10.10 and MCU 5.0737.3.0.1
Thanks!
Old 03-06-2009, 16:30   #7 (permalink)
Member: 478218
Thanks Meter: 5
sir my name is azmath sir my mobile is 6070 problem is phone reciption code iam flash the 6070 in jaf and cell is on but after 10 minuts mobil was dead how sallow this problem
Old 03-06-2009, 16:35   #8 (permalink)
Member: 478218
Thanks Meter: 5
bujjji
sir i want dct4 flash fils how to down fils]
Old 03-06-2009, 19:12   #9 (permalink)
Member: 125
Sonork: 100.100000
Thanks Meter: 1,305
Arrow
Hi flash it with latest firmware... / unlock it then just use...
Old 03-06-2009, 19:22   #10 (permalink)
sniper007's Avatar
Member: 722656
Sonork: 100.1584918
Thanks Meter: 294
which box r u using. just go the the support website of that box and download it from there. otherwise search it you will for use get it on net as well
Old 03-07-2009, 11:18   #11 (permalink)
Member: 254086
Thanks Meter: 24
No soultion for that daed n70
Thanks!
sir i have download that sw which u said then i falsh it but no improvement so what could be a problem
And one quetion JAF by Odeon N JAF support is one or Diffrent ?
Thank u
Old 03-08-2009, 06:17   #12 (permalink)
Member: 125
Sonork: 100.100000
Thanks Meter: 1,305
Hi...,
Can you post the flash log here... and about JAF
Both are same Project marketed by two different channels with separate support sections...
Thanks!
Old 03-08-2009, 09:48   #13 (permalink)
Member: 147974
Sonork: 100.1596166
Thanks Meter: 97
Plz post here full log then i can help u.
Old 03-08-2009, 10:39   #14 (permalink)
Member: 254086
Thanks Meter: 24
This is log of that dead n 70
JAF version 1.98.61
Detected PKEY: 900242D9
Card life counter: 90.13%
P-key nokia module version 01.02
Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
USB Cable Driver version: 7.1.8.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-84\
Scanning for ini files...
INI file .ini is missing. Continue searching for second ini type...
Changing flashing settings...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50647301.C0
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\V150647301_RM84rd.VP3
APE Variant file: ?
Manual mode selected, version can't be checked!
Booting phone...
APE Boot Data:
Asic ID: 17100701
Asic Mode ID: 00
Asic Public ID: 6A9E562CD5C2EDA0DDC9F2F4E4774D70C7E13626
HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000
ROM ID: AB5E4ADB27A06946
CMT Boot Data:
Asic ID: 000000010000022600010006000C192101002200
Asic Mode ID: 00
Asic EM ID: 00000353
Asic Public ID: 1BE00111E491605121D00235EE292915C6227714
HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000
ROM ID: F28A211FCEA7B19D
CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg
Loader version: 01.15.00 -> Revision: 0000
Patching CMT boot step2...
CMT Boot Ready
CMT Flash ID: 0000FFFF <=> BAD FLASH VENDOR -> BAD FLASH TYPE
CMT Flash Data: 5C4E6F6B69615C50686F656E69785C50
CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
Loader version: 01.21.01 -> Revision: 0000
CMT Loader Ready
APE Boot: C:\Program Files\ODEON\JAF\Flash\helen3_2nd.fg
Loader version: 01.23.00 -> Revision: 0000
Patching APE boot step2...
APE Boot Ready
APE Flash ID: 00360098 <=> SAMSUNG -> Type not in database
APE Flash Data: 00020000000600000000000000000000
APE Loader: C:\Program Files\ODEON\JAF\Flash\h3_sam_nand_gbbm.fg
Loader version: 01.21.00 -> Revision: 0000
Patching APE loader step2...
APE Loader Ready...
Operation took 0 minutes 7 seconds...
Sending CNF Data...
Erasing...
Operation took 0 minutes 0 seconds...
Writing..
Booting phone...
APE Boot Data:
Asic ID: 17100701
Asic Mode ID: 00
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
APE Boot Ready
APE Loader Ready...
Sending CNF Data...
Erasing...
Writing...
Stage 1
Sending CMT HASH for NOLO
Sending APE HASH for KEYS
Sending APE HASH for X-LOADER
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending APE HASH for PRIMAPP
Sending CMT HASH for DSP0
Sending APE HASH for SOS+LOADER
Sending APE HASH for SOS+XZIP
Sending APE HASH for PASUBTOC
Sending APE PUB KEYS...
Sending APE HASH for SOS*CORE
Sending CMT HASH for MCUSW
Sending CMT HASH for PASUBTOC
Sending CMT PUB KEYS...
Stage 2
Operation took 2 minutes 47 seconds...
Reseting phone...
PPM: C:\Program Files\Nokia\Phoenix\Products\RM-84\V150647301_RM84rd.VP3
Booting phone...
APE Boot Data:
Asic ID: 17100701
Asic Mode ID: 00
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
APE Boot Ready
APE Loader Ready...
Operation took 0 minutes 6 seconds...
Sending CNF Data...
Erasing...
Operation took 0 minutes 3 seconds...
Writing...
Operation took 2 minutes 2 seconds...
Reseting phone...
Done!
Total time: 5 Minutes, 7 Seconds
DCT4/BB5 counter: 85
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
Old 03-08-2009, 10:43   #15 (permalink)
Member: 638396
Sonork: 100.1615405
Thanks Meter: 170
CMT Boot Ready
try with other box.., or reheat NOR Flash
E65 is dead, how to flash it? myvicky Nokia Base Band 5 ( BB-5 ) 24 09-03-2010 08:46
Nokia 6700 Classic. Is there anyway to flash it succesfully ???? eskerra HWK 3 01-28-2010 00:48
gx-15 dead , how to flash it?? summer_20xx ThunderStorm Box 22 07-03-2009 16:43
U700 dead how to flash it ... fawzi faouzi NSPRO 5 08-03-2008 01:41
6630 dead ...how to flash it back ?? kit_kit MT-BOX 6 06-25-2007 12:18
Page generated in 0.31886 seconds with 9 queries
