01-17-2009, 16:13 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: :::::::EMIRATES:::::::
Member: 591669 Status: Offline Sonork: 110011 Thanks Meter: 687 | sim not vcaliud i try in unlock, imei and rpl reading is ok but error unlocking and write rpl problem still i need clear soulution |
01-17-2009, 18:19 | #3 (permalink) |
Member: 591669 Status: Offline Sonork: 110011 Thanks Meter: 687 | iam already unlock in thoamas pkey ,error in unloacking Backing up SIMLOCK data... Setting local mode... Reading IMEI... C:\Program Files\ODEON\JAF\ProgData\353269011015017_CRT_backu p_2119171.pm Done! Backup LCK OK! Setting local mode... Reading simlock data... LOCK STATUS: CONFIG KEY: FFFFFFFFFFFFFFFF PROVIDER KEY: FFFFFFFFFFFFFFFF Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 00101F Reading imei... Reading codes data... Found codes data... Resetting phone... Waiting for phone... Reading soft info... Reading simlock data... Writing codes data... Unlock Codes: #pw+759790415729678+7# #pw+802229300945382+6# #pw+759233642528937+5# #pw+574389894868222+4# #pw+723062103665732+3# #pw+677108180526958+2# #pw+555691877202215+1# Uploading code to phone... Reseting phone... Waiting for phone... Reading soft info... Unlocking... Error unlocking... |
01-17-2009, 18:41 | #4 (permalink) |
No Life Poster Join Date: Mar 2008 Location: London
Member: 722656 Status: Offline Sonork: 100.1584918 Thanks Meter: 294 | if not working with jaf then try with bb5_unlocker. you can download the software from link below in case if you dont have it. http://nokia.nigelcoldwell.co.uk/bb5/ |
The Following User Says Thank You to sniper007 For This Useful Post: |
01-17-2009, 18:47 | #5 (permalink) |
No Life Poster Join Date: Dec 2007 Location: egypt
Member: 648590 Status: Offline Thanks Meter: 267 | CONFIG KEY: FFFFFFFFFFFFFFFF PROVIDER KEY: FFFFFFFFFFFFFFFF you need Repair sl zone on bb5 king or unlock on Thomas PKEY Last edited by tornado2008; 01-17-2009 at 18:56. |
01-17-2009, 19:06 | #6 (permalink) | |
Member: 591669 Status: Offline Sonork: 110011 Thanks Meter: 687 | Quote:
01-18-2009, 15:40 | #10 (permalink) | |
Member: 722656 Status: Offline Sonork: 100.1584918 Thanks Meter: 294 | Quote:
open the files in this archive to c:\bb5_unlocker so the directory structure looks like: which means that creat a folder in C drive and extract all the files in that folder as shown below: C:\bb5_unlocker\backup C:\bb5_unlocker\logs C:\bb5_unlocker\psw C:\bb5_unlocker\install.bat C:\bb5_unlocker\list.txt C:\bb5_unlocker\bb5logunlock.txt C:\bb5_unlocker\BB5logunlocker.exe C:\bb5_unlocker\BB5_calc.exe C:\bb5_unlocker\logs\bb5_unlocker.cfg Connection ********** For this program you need Fbus cable like DK5, CA43 or similar connected to one of the ports from COM1 to COM9. This must be the correct cable for the phone, not just one that fits. Edit the File C:\bb5_unlocker\logs\bb5_unlocker.cfg using notepad or similar to the correct port for your FBUS cable. By default it reads COM2: You can find your correct port my looking in your device manager. (right click my computer - properties - hardware - device manager - ports) Using ***** the programme BB5logunlocker.exe can only be launched if the .cfg file has been edited properly. which means that you have to mention the right com port as explaned above: Connect the phone with the SIM card removed launch BB5logunlocker.exe Unlocking ********* Click 'read phone', this will display some info regarding the phone including the lock status. Click 'Back Up' do not modify this file. Click 'Make Log' this will add a file to the logs folder for your phone. Launch BB5_calc.exe this can use the log file to calculate the unlock code for your phone. This will be saved to th folder PSW. Click SP unlock - Unlocking done. i hope it helps you, always read first then write if you dont understand it. | |
Tornado SIM not Work with Movistar Sim Mexico | gniusmx | TORNADO - SIM | 0 | 07-20-2008 21:08 |
china sim not valid or sim cad rgistration faild | classic mobiles | Chinese Models & Cloned Phones | 15 | 07-05-2008 14:40 |
E700-32K Sim OK, 64K SIM Not Accepted | Qantas | Trident/AGERE Platform | 0 | 04-28-2005 13:26 |
mw3026 SIM not present with SIM inside | adypet1 | Infineon C16X M51 & ARM7 M52 BASED | 19 | 05-09-2004 16:53 |
Sagem MW 936E Sim not present with or without sim card | florinmar | Infineon C16X M51 & ARM7 M52 BASED | 7 | 11-04-2002 15:43 |
