6280 restart after unlock i came across a few 6280 which was unlocked and got problems after that. when trying to transfer music files via bluetooth, the phone got dead and had to flash again and the problem persists again and again even after trying several version of flash files.... has anyone came across this? i use UID for unlock and JAF or UFS to flash the phones.. any suggestion or help would be much appreciated WBR Mehvishal |
Yes this is 6280 behaviour not only the unlocked one .. but i find this even in unbranded version of 6280 |
any special file to use in order not to get that each time? any special instruction that you know that can help prevent that? |
Flash back the phoen at its orignal version.ur problem would be solved. |
Hi guys? That is a common fault with 6280/8. I have has similar experiences, particularly with the 3UK (6.43) Firmware, and I resorted to flashing it with different, mainly the 02 packages, and the fault seems to go away. I had been flashing the original firmware based on the original product code. I think it is just a manufacturers fault, as at times they just go dead while transferring something via bluetooth, or even simply changing themes. There is one I have flashed over 10 times, and it keeps recurring, so looks like we are yet to get a permanent cure for them... |
the problem is caused when the internal memory is nearly full. then any file sent to the fone exceeding the internal free memory will crash it again n again to solve it u must ask customer not to save anything on fone memory , not only locked forns having this error but fone buy from nokia alos , made in finland or by nokia all have this bugs ryaz |
