Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UID - Box
Old 09-18-2007, 11:33   #1 (permalink)
Member: 72851
Thanks Meter: 28
N73 Unlocking problem!
Can anyone help me??
I confirm tp are connected!!
Is this unsupported flash chip?
Old 09-18-2007, 12:35   #2 (permalink)
GSM Road Runner's Avatar
Member: 107839
Sonork: 100.1592822
Thanks Meter: 70
Did u update your box firmware with latest version?
Old 09-18-2007, 13:03   #3 (permalink)
Member: 72851
Thanks Meter: 28
i already updated for 2-3 time already but still same problem !!
I already try more than 10time but still the same problem!!
Old 09-18-2007, 13:15   #4 (permalink)
lemor's Avatar
Member: 38562
Thanks Meter: 1,478
we already unlock one piece of n73 using this CLOWN BOX...hehehe
but we tried it again same error stated above...
Old 09-18-2007, 13:34   #5 (permalink)
Member: 72851
Thanks Meter: 28
[QUOTE=lemor;2722702]we already unlock one piece of n73 using this CLOWN BOX...hehehe
[/QUOT
That mean successful or not ???
Old 09-18-2007, 14:14   #6 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Thanks Meter: 6,027
Pls keyin the code by hand, try to use +4# or +6#, this very easy for unlock !
BR.,
Denis
Old 09-18-2007, 14:28   #7 (permalink)
Member: 72851
Thanks Meter: 28
@.::Gsmdenis::.
Sir, I don't is possible to solder wire to n73 TP, i'm using needle method!
Is there any way to key-in such code using any 3rd party software???
Old 09-18-2007, 14:33   #8 (permalink)
Bomber's Avatar
Member: 1756
Thanks Meter: 9
use dejan software to enter code +4# etc..
but you need another hand
Old 09-18-2007, 14:36   #9 (permalink)
Member: 107839
Sonork: 100.1592822
Thanks Meter: 70
according to this, soon we will start to use also with legs...
Old 09-18-2007, 16:06   #10 (permalink)
Member: 72851
Thanks Meter: 28
Hi,
This phone got some weird case, as dejan s/w cannot read info when I'm using com port but i can read with dku-2 for USB via DSS!
Using the same com port , I can read 6680 info and unlock via dejan s/w!
Got any other solution??
@UID Team
Pls updated will auto-send other code for +4# and +6# else we really getting trouble when using UID!
Old 09-18-2007, 17:18   #11 (permalink)
shadi's Avatar
Member: 35002
Sonork: 100.98829
Thanks Meter: 167
Wink use duk2 with power suplly cable
Originally Posted by Gsm-W View Post
Hi,
@UID Team
use dss but you must have duk2 power supply cable (local mode)
Old 09-18-2007, 17:36   #12 (permalink)
Member: 72851
Thanks Meter: 28
Sir,
Even I'm able to switch to local mode also facing the same problem! I'm using external power supply 68k between BSI and gnd and 10k or 5.1k for serial with BSI line.
Try to check my pic again! It just hang at there after DSS have done it job.
Any more good advise?
Old 09-18-2007, 17:41   #13 (permalink)
shadi's Avatar
Member: 35002
Sonork: 100.98829
Thanks Meter: 167
Sir,
yes sure but the code manual +2# +3# +4# ..... +7#
Old 09-18-2007, 17:46   #14 (permalink)
Member: 72851
Thanks Meter: 28
As u guyz also understand there is no way to solder the wire to N73 TP cause my limited skill!!
Is there anyway to sent the code to the mobile via DSS or any other ways?
As I mention before, this phone are not able to detect using com-port to unlock using dejan s/w!!
Old 09-18-2007, 17:47   #15 (permalink)
Member: 72851
Thanks Meter: 28
What I mean +2# +3# +4# ..... +7# using usb??
Thanks for those who reply!
N73 Unlocking Problem help ? fanig UID - Box 4 09-28-2007 03:24
n73 unlock problem bronks MT-BOX 2 09-18-2007 14:16
n73 unlock problem aligsmpak MT-BOX 2 08-01-2007 22:57
n73 unlocking problem EFOKORKU MT-BOX 4 07-26-2007 12:49
N73 Unlock Problem Nasmi MT-BOX 1 07-21-2007 09:01
Page generated in 0.21590 seconds with 10 queries
