11-10-2007, 19:34 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: UK
Member: 232050 Status: Offline Thanks Meter: 23 | N95 not unlocking please help!!!!!!!!! I cannot understand why the 1st phone unlocked so easily and i try for hours but cannot do the other 2, the testpoints are pretty easy to make on this phone - i have tried needles and soldering methods for vga 4 and vga 5. I am tearing my hair out over this, please tell me what i am doing wrong!!!!! |
11-10-2007, 20:05 | #2 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Sousse /trockadero/TUNISIA
Member: 193003 Status: Offline Thanks Meter: 46 | i get error such as testing challenge code 03 and missing code trying again in 20 seconds... about this phone n95 ..read phone info with jaf..i think rpl damage...you will find key config.FFFFFFFFFFFFFFFFFFFF post logg her |
11-14-2007, 12:24 | #4 (permalink) |
Member: 232050 Status: Offline Thanks Meter: 23 | Hi, I read with JAF and config key is 2343300000000000. I'm sure my testpoints are being made properly, the amount of times i have tried to unlock this phone i coud not do bad testpoint everytime! |
11-14-2007, 16:05 | #6 (permalink) |
Member: 232050 Status: Offline Thanks Meter: 23 | I have tried both methods, when i use keypad i get 'not allowed' which i guess means the keypad method cannot be used now, and dss, which seems to enter the code as it should. Here is uid log; Server: [70.85.181.2], port: [35555] Will use server 70.85.181.2 to port 35555 BB5 box connected, awaiting commands. Request box ID. ************************************************** ************************************ BOX INFO: ID: 2f42, VERSION: beef, HW_REV: cb, SW_REV: 01 ************************************************** ************************************ Connecting server...Server conected. Requesting data...Got page, exiting! Got auth: [23d1bb076b3e28acf0bb4e39235c702a432b31f25224467b45 7e43c2d02a5b8000], ssid: [119505164520488] Incoming auth_req len: 33 23 d1 bb 07 6b 3e 28 ac f0 bb 4e 39 23 5c 70 2a 43 2b 31 f2 52 24 46 7b 45 7e 43 c2 d0 2a 5b 80 09 Requested Secret **SECRET_ANSWER: 2f42beef1d80fe85cfab985803666830b209d84013a1d04add 49a8a0d04857f466db5b5c15 Connecting server...Server conected. Requesting data...Got page, exiting! Got unlock block: [16e6340fd15528fa57fc5b29ef469bb3bacddfa1cf20dedae2 e364ae6c24c0dd5770221aec70bee16084dbef533b04a0a8fc 165060244db60875adc3433c28c880c0aca0ebd09be71f462c fc303b455423f230d3af418c351887af70e9fbfbe92748a80e 52cb1ace2adaefbfe0a0bf4df3da4e914ce6f3fc981bf5d6d9 4bdf8b00] Sending UNLOCK string(128 bytes) unl_log: 01 unl_log: 02 unl_log: 30 unl_log: 03 unl_log: 33 Please press '#pw+293062541677515+1#' on phone keypad NOW! Testing challenge code 03 Testing challenge code 02 Incomplete challenge - code missing. Box will try again in about 20 seconds Box ready to retry! unl_log: 04 unl_log: 03 unl_log: 33 Please press '#pw+680754751726088+1#' on phone keypad NOW! I get this kind of message everytime - the testpoint is easy so i am sure it is connected correctly - i have even soldered it and my wires are very short. here is JAF info when i read the phone; JAF version 1.98.40 Detected PKEY: 90001C21 Card life counter: 91.91% P-key nokia module version 01.00 Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ Changing mode...Done! Searching for phone...Detected P-KEY: 90001C21 P-key nokia module version 01.00 Init usb communication... Found MCU SW version: V 06wk41v18.4 13-03-07 RM-159 (c) Nokia HW version: 5650 PCI version: RFIC version: 17141714 DSP version: ibusal_aalto_06wk41v20 APE SW Core version: 10.0.018 APE Variant version: 10.0.01801 APE Test version: rm159_ENO_x_2007wk02v0.070 Retu version: 15 Tahvo version: 21 APE HW version: 1 APE ADSP SW version: 256 Camera version: 1 APE BT version: HCI Version 8 (rev. 0). LMP Version 32 (rev. 4127). Manufacturer 13064. Production serial number: SAM913212 Product code: 0536062 Module code: Basic production code: 0530865 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 352255013559806 IMEI spare to net: 3A 25 52 05 31 55 89 00 IMEI SV to net: 33 25 52 05 31 55 89 00 F3 LOCK STATUS: CONFIG KEY: 2343300000000000 Provider: Orange;United Kingdom Key Code count: 3, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23433F Block 2: Lock 1: CLOSED -> Lock Data: 23486F Block 3: Lock 1: CLOSED -> Lock Data: 23433F Block 4: Lock 1: CLOSED -> Lock Data: 23486F Loading INI list... Detected P-KEY: 90001C21 P-key nokia module version 01.00 Init usb communication... Reading product code... Product Code: 0536062 What am i doing wrong???????????/ |
11-17-2007, 19:33 | #11 (permalink) |
Member: 232050 Status: Offline Thanks Meter: 23 | Hi, thanks for your help. I flashed with apac version but still got the same kind of problems. In the end I did ask-rpl and unlocked it 1st time using keypad input method. Seems strange that the phone would not unlock with dss using cable. I can confirm that problem was not with vga8 connection. Anyway, phone is now unlocked hooooray! |
11-22-2007, 12:30 | #12 (permalink) |
No Life Poster Join Date: Mar 2006 Location: lost in a supermarket
Member: 239318 Status: Offline Thanks Meter: 51 | thanks for helpful information, exactly witch version u downgraded ir? 10.0.18 withour minus updates? i have same problem, same keypad 3, same operator locks and no unlock, will provide with rpl..... sob |
nokia 5800 not unlock please help - loader password not accepted [SOLVED] | servisoft | Cyclonebox | 3 | 10-07-2009 19:22 |
K550i CID51 not unlocking, please help!!!!! | masterunlocking | FuriousGold | 5 | 11-24-2007 22:16 |
Nokia 1600 ... not unlock..please help | tical | MT-BOX | 1 | 11-12-2006 16:25 |
LG U8120 could not unlock - Please HELP!!! - | KUBAT1 | LG | 2 | 12-28-2004 15:40 |
Z5 not unlocked!!!Please help!! | razor | Sony | 8 | 05-31-2002 19:24 |
