G502 unlock problem ... Hi guys! Just tried on two different computers to unlock G502, but on both computers I get the same situation: Using 2.21 ver.: [ --- EraseLock --- ] Power off phone with battery,Press C key & plug DCU-60 in ... Connect to phone success! Baseband ID:C900 Protocol version:0401 and phone stays at this line till disconnect it from cable ... I've got this situation when received the phone for unlock, after that flashed it with complete option and tried again, but still the same ?! BR, sid |
Is the phone 100% working??? BR, Tito Millo |
Yes friend! it's a brand new phone - making and receiving calls ... I can read info from phone and flash it with setool. First I thought it is some kind of a problem booting it on the computer I use seking, but when tried it on another comuter I saw the same problem. I also forgot to mention that this phone is powered from the (C) button so I'm connecting it using the (2+5) + plugging in the usb cable. BR, sid |
you can press 2 or 5 singly to try |
Yesssss ! Thanx a LOT friend! Pressing just 5 + plugging in the usb cable worked :) BR, sid |
But not work even with 5+usb cable in SW waits for something, I dont know what. (I use 2.22) I will try to flash then try again. BR Rak|m |
Solved worked perfect after flash, I really dont know why, flashed with same version but generic flash and other customization. Thank you Rak|m |
