Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Seking Server
Old 09-01-2009, 05:45   #1 (permalink)
Member: 125606
No code message says CSCA server working, is this true?
This is the message I received:
No Code For The IMEI(35575502XXXXXXX) In Server.
****Please Select CSCA Unlock Option,It's Working Now.****
As well, are the unlock codes updated frequently? Should I check for an unlock code again next week if the CSCA server is not running?
Old 09-03-2009, 07:16   #2 (permalink)
Member: 125606
Should I assume the message that the SEKing Server has given is incorrect?
If so, I need to return the phone to my customer.
TIA!
Old 09-04-2009, 07:32   #3 (permalink)
Member: 724413
Thanks Meter: 205
if no codes,you must use csca server.
Old 09-04-2009, 16:55   #4 (permalink)
Member: 682200
Thanks Meter: 34
CSCA server not still not working
is this update release? Is this true or false? jumper-master BB5 No TP By Jafsupport 7 04-03-2010 07:14
Is this true way to unlock or no ???? rundll-exe Universalbox 3 03-13-2009 22:48
this code 1511 for bp acd 9431 is it true sib0585 CAR Electronics 1 04-12-2008 18:58
Page generated in 0.14460 seconds with 9 queries
