06-28-2008, 19:37 | #1 (permalink) |
Freak Poster Join Date: May 2006
Member: 278535 Status: Offline Thanks Meter: 12 | how to unlok w350i? please could you help with this matter thanks |
07-10-2008, 01:30 | #3 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Where money is made Age: 33
Member: 390642 Status: Offline Sonork: 100.1573430 Thanks Meter: 2,476 | Press 2 key and conect phone to DCU-60 cable this will work BR, Tito Millo Last edited by tito millo; 07-10-2008 at 15:29. |
07-10-2008, 01:37 | #4 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: sn,fdo,lu philippines
Member: 288470 Status: Offline Sonork: 100.1605122 Thanks Meter: 664 | Quote:
successfully unlocked W530i(PNX5230) FREE!!! 7/9/2008 6:03:32 PM SIGNED MODE (USING SERVER). 7/9/2008 6:03:32 PM ALTERNATIVE SECURITY BYPASS ENABLED. 7/9/2008 6:03:32 PM ChipID000,EMP protocol:0301 7/9/2008 6:03:32 PM 7/9/2008 6:03:32 PM PHONE IS RED RETAIL PRODUCT 7/9/2008 6:03:32 PM FLASH CID detected:53 7/9/2008 6:03:32 PM Speed:921600 7/9/2008 6:03:33 PM OTP LOCKED:1 CID:52 PAF:1 IMEI:35438802224701 CERT:RED 7/9/2008 6:03:33 PM LDR:071213 1552 PERCXC1720441_R2A022_PNX5230_FLASHLOADER 7/9/2008 6:03:33 PM Flash ID check:897E 7/9/2008 6:03:33 PM Flash props sent ok 7/9/2008 6:03:38 PM LDR:070904 1356 AN2CXC1250610_R3A016_PNX5230_CSLOADER 7/9/2008 6:03:38 PM loader startup: executed 7/9/2008 6:03:42 PM loader GDFS startup: executed 7/9/2008 6:03:46 PM loader filesystem startup: executed 7/9/2008 6:03:46 PM loader unlock: executed 7/9/2008 6:03:51 PM 7/9/2008 6:03:51 PM DISCONNECT PHONE NOW 7/9/2008 6:03:51 PM INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN 7/9/2008 6:03:51 PM BE SURE THAT YOU SET PHONE IN "PHONE MODE" 7/9/2008 6:03:51 PM IF ASKED, INSTALL PHONE DRIVERS 7/9/2008 6:03:51 PM 7/9/2008 6:03:51 PM SEARCHING FOR PHONE, "STOP" TO ABORT 7/9/2008 6:04:48 PM PHONE FOUND AT COM45 7/9/2008 6:04:55 PM PHONE READY TO PROCEED 7/9/2008 6:05:06 PM EXECUTOR STARTED 7/9/2008 6:05:06 PM 7/9/2008 6:05:06 PM REMOVE CABLE FROM PHONE 7/9/2008 6:05:06 PM REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK 7/9/2008 6:05:06 PM THEN PRESS "READY" 7/9/2008 6:05:23 PM 7/9/2008 6:05:25 PM ChipID000,EMP protocol:0301 7/9/2008 6:05:25 PM 7/9/2008 6:05:25 PM PHONE IS RED RETAIL PRODUCT 7/9/2008 6:05:25 PM FLASH CID detected:53 7/9/2008 6:05:25 PM Speed:921600 7/9/2008 6:05:26 PM Trying to launch embedded bootloader... 7/9/2008 6:05:26 PM INT LDR:PNX5230_PRELOADER_FOR_SETOOL2 7/9/2008 6:05:26 PM Flash ID check:897E 7/9/2008 6:05:26 PM Flash props sent ok 7/9/2008 6:05:42 PM FOUND: R10BA015_1204-3117_GENERIC_JH 7/9/2008 6:05:42 PM Restore from:R10BA015_1204-3117_GENERIC_JH 7/9/2008 6:05:51 PM full sig complete. 7/9/2008 6:05:51 PM USERCODE RESET TO "0000" 7/9/2008 6:05:51 PM Searching... 7/9/2008 6:05:52 PM Firmware SIMLOCK check determined. 7/9/2008 6:05:56 PM Unlock DONE 7/9/2008 6:05:56 PM Elapsed: 143 secs. br keaelite | |
07-10-2008, 12:54 | #5 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | Successul W350 permanent unlock Successfully unlocked permanently W350i via Seking server and all this in just 10 minutes or less. Code: Seking Unlocker(v2.14) [ --- Query Credits --- ] Connecting server(1)... Connect to server(1) success! User authen success! Left Credits:80 Close connection success! Connecting server(2)... Connect to server(2) success! User authen success! Left Credits:80 Close connection success! Time: 00min 07sec [ --- EraseLock --- ] Power off phone with battery,Press C key & plug DCU-60 in ... Connect to phone success! Baseband ID:D000 Protocol version:0301 Color: Red EROM CID:53 OTP CID:52 OTP LOCK:1 IMEI:35438802354192 Connecting server... Connect to server success! User authen success! Erasing Lock Request Sent! Credit need:4, credit left:80 Important notice:your requested data has been sent to server for calculation,erasing lock is not done currently,you should re-erase lock later until appearing erase lock success in message box.to do step 2 unlock will waste your credit if you don't get the message erasing lock success.erase lock only deducts credits at 1st time for the same phone. Time: 00min 08sec [ --- EraseLock --- ] Power off phone with battery,Press C key & plug DCU-60 in ... Connect to phone success! Baseband ID:D000 Protocol version:0301 Color: Red EROM CID:53 OTP CID:52 OTP LOCK:1 IMEI:35438802354192 Connecting server... Connect to server success! User authen success! Erasing Lock Request Sent! Important notice:your requested data is already in queue now,erasing lock is not done currently,you should re-erase lock later until appearing erase lock success in message box.to do step 2 unlock will waste your credit if you don't get the message erasing lock success.erase lock only deducts credits at 1st time for the same phone. Time: 00min 07sec [ --- EraseLock --- ] Power off phone with battery,Press C key & plug DCU-60 in ... Connect to phone success! Baseband ID:D000 Protocol version:0301 Color: Red EROM CID:53 OTP CID:52 OTP LOCK:1 IMEI:35438802354192 Connecting server... Connect to server success! User authen success! Erasing Lock Request Sent! Important notice:your requested data is already in queue now,erasing lock is not done currently,you should re-erase lock later until appearing erase lock success in message box.to do step 2 unlock will waste your credit if you don't get the message erasing lock success.erase lock only deducts credits at 1st time for the same phone. Time: 00min 04sec [ --- EraseLock --- ] Power off phone with battery,Press C key & plug DCU-60 in ... Connect to phone success! Baseband ID:D000 Protocol version:0301 Color: Red EROM CID:53 OTP CID:52 OTP LOCK:1 IMEI:35438802354192 Connecting server... Connect to server success! User authen success! Erasing Lock Request Sent! Save data from server success! Send applet ... Applet version:071213 1552 PERCXC1720441_R2A022_PNX5230_FLASHLOADER Flash ID:0x897E Send applet ... Applet version:071213 1552 PERCXC1720441_R2A022_PNX5230_FLASHLOADER Phone Hardware Initialize complete! [ --- Start GDFS & FileSystem --- ] Send applet ... Applet version:070904 1356 AN2CXC1250610_R3A016_PNX5230_CSLOADER Start GDFS service,please wait... Erasing Lock... Erasing Lock Success! Disconnect Phone Success! Time: 00min 12sec [ --- Query Credits --- ] Connecting server(1)... Connect to server(1) success! User authen success! Left Credits:76 Close connection success! Connecting server(2)... Connect to server(2) success! User authen success! Left Credits:76 Close connection success! Time: 00min 08sec [ --- Query Credits --- ] Connecting server(1)... Connect to server(1) success! User authen success! Left Credits:76 Close connection success! Connecting server(2)... Connect to server(2) success! User authen success! Left Credits:76 Close connection success! Time: 00min 08sec [ --- Start Unlock --- ] Power on phone with battery,plug DCU-60 in ... Found Sony Ericsson Device A016 USB WMC Modem(COM8)! Open COM8 success(9600)! IMEI:354388023541924 Connecting server... Connect Server Success! User authen success! Credit need:1, credit left:76 Unlock request sent, wait server process... Don't terminate,your request is in queue,please wait... Ready for unlocking,don't disconnect phone,please wait... Authenticate 1 success! Authenticate 2 success! Authenticate 3 success! Authenticate 4 success! Authenticate 5 success! Authenticate 6 success! Authenticate 7 success! Authenticate 8 success! Unlock success! Time: 01min 14sec BR |
07-12-2008, 00:01 | #6 (permalink) |
Major Poster Join Date: Jan 2008
Member: 668144 Status: Offline Thanks Meter: 4 | help ..... to ... correct detection If all method not work you can use this image for guide and unlock Remember for setool User choice in settings option 1 and 4 |
The Following User Says Thank You to nrslgsm For This Useful Post: |
10-04-2008, 07:38 | #8 (permalink) |
No Life Poster Join Date: Mar 2006 Location: shandar chock jelum pakistan
Member: 241661 Status: Offline Thanks Meter: 265 | think .keaelite. just PRESS "2" then plug ur USB cable tested by me. Loaded 51 flash descriptors SIGNED MODE (USING SERVER). ChipID000,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 skipping empty loader... OTP LOCKED:1 CID:52 PAF:1 IMEI:35586502844776 CERT:RED Model:W350i Brand:Vodafone ES MAPP CXC article: R10BA015 prg1205-7402_VODAFONE_JH MAPP CXC version: R10BA015 Language Package:VFE_LIVE_1 CDA article: 1208-9089 CDA version: R7A Default article: 1204-3119 Default version: R10BA015 PROVIDER: 214-01 Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 39 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID000,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 Speed:921600 OTP LOCKED:1 CID:52 PAF:1 IMEI:35586502844776 CERT:RED LDR:071213 1552 PERCXC1720441_R2A022_PNX5230_FLASHLOADER Flash ID check:897E Flash props sent ok LDR:070904 1356 AN2CXC1250610_R3A016_PNX5230_CSLOADER loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN BE SURE THAT YOU SET PHONE IN "PHONE MODE" IF ASKED, INSTALL PHONE DRIVERS SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM158 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" ChipID000,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 Speed:921600 Trying to launch embedded bootloader... INT LDR:PNX5230_PRELOADER_FOR_SETOOL2 Flash ID check:897E Flash props sent ok FOUND: R10BA015_1205-7402_VODAFONE_JH Restore from:R10BA015_1205-7402_VODAFONE_JH full sig complete. USERCODE RESET TO "0000" Searching... Firmware SIMLOCK check determined. Unlock DONE Elapsed: 321 secs. |
How to flash W350i with SEtool? What is that's fatal? | Wais777 | SETool2 | 8 | 07-30-2009 14:01 |
How to unlock W350i | atukhi | Sony Ericsson | 1 | 04-06-2009 10:33 |
how to unlock w350i | campus | SETool2 | 2 | 12-29-2008 17:27 |
how to dismantle w350i | gulam khadir | Sony Ericsson Hardware Repair | 0 | 10-23-2008 14:09 |
>>> how to detect W350i in usb <<< | keaelite | SETool2 | 13 | 10-14-2008 08:22 |
