10-14-2007, 02:12 | #2 (permalink) |
Freak Poster Join Date: Nov 2006 Location: PL
Member: 384541 Status: Offline Thanks Meter: 101 | that is translating from china language : "Increased K750 brushing machine (K750 only to supply test). Revised the contact surface style and the operation custom, simply causes the operation to be convenient. The single solution network locks no longer needs to add the master file, but needs to download website in Unlock_Files.rar, after the decompression puts the complete document to the Unlock_Files table of contents under." Br |
10-16-2007, 20:01 | #5 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ..still in idle mode...
Member: 3900 Status: Offline Thanks Meter: 31 | 2007-10-15 Seking3.0.4.4 1.Add K750 flashˇ˘customize(only test) 2.Change application style. 3.Support UnlockFiles. No need main file for unlock. |
10-19-2007, 07:08 | #6 (permalink) |
No Life Poster Join Date: May 2001 Location: Hungary Age: 55
Member: 4695 Status: Offline Thanks Meter: 15 | to Sekingserver team! hi friends! this new tool larger than 1024*768 and not visible total view! I know this is little bit problem, but I have that resolution. And one more , can't return to the support top-left window after if do anything operation?!(deosn't worked before!) Please fix it , tnanks in advance. BR , Keni Last edited by Keni; 10-19-2007 at 07:16. |
10-21-2007, 00:21 | #8 (permalink) | |
Freak Poster Join Date: Jun 2004 Age: 48
Member: 69631 Status: Offline Thanks Meter: 42 | Quote:
is it simply to download the 142 mb unlock file and unzip it to your seking/unlock_files folder ?? please help as eirlier ive lost 6 logs due to the program keep failing with error "unlock file not found" cheers if you can help. lolly_pop | |
10-21-2007, 10:05 | #9 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 440163 Status: Offline Thanks Meter: 2,470 | Quote:
SeKing 3.0.7.1 what's new in English please | jepetu | Seking Server | 2 | 03-12-2008 21:21 |
SeKing 3.0.7.1 what's new in English please | jepetu | Seking Server | 0 | 03-01-2008 13:01 |
Seking 3.0.4.9 test | ZIYAAD STRYKER | Seking Server | 2 | 11-18-2007 10:37 |
New Update From Seking Server 3.0.4.6!!! | υИқИΘШИ® | Seking Server | 0 | 10-25-2007 08:14 |
New Broken Arrow version 1.0.0.4 to support new NSS 1.0.3.8.11.exe | GUDO-GSM | Federal One | 0 | 06-30-2007 06:50 |
