Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5BOX Products > BB5BOX
Old 10-30-2007, 15:29   #16 (permalink)
GSM_N4H's Avatar
Member: 211652
Thanks Meter: 120
thank you man
i have done after a hour
yes soulation is woring 100%
Searching for phone ...
Phone found on FBUS interface
Reading phone info ...
Type: RM-174
Version: V_05.00_27-04-07_RM-174_(c)_Nokia.
IMEI: 357672015621464
SP LOCK status:
    Config Key: 2343300000000000
    Block 1: CLOSED  Type 5      Data: 23433F
    Block 2: CLOSED  Type 5      Data: 23486F
Keyboard wrong codes counter: 0 wrong tries from max. 3 tries
Cable wrong codes counter: 10 wrong tries from max. 10 tries
Reset phone in TEST mode ...
Set Full Factory Defaults ...
Reset phone ...
Full Factory Defaults set OK
Skip autobackup of PM 308
Autobackup file:
RM-174_357672015621464_Locked_Keycnt_0_Fbuscnt_10__V_05.00_27-04-07_RM-174_(c)_Nokia..bin
already exist
Auto Write PM 308 procedure started
Searching for backup file with lowest FBUS count ...
Finded backup file: RM-174_357672015621464_Locked_Keycnt_0_Fbuscnt_0__V_05.00_27-04-07_RM-174_(c)_Nokia..bin
Writting PM Field 308 Subfield 1 with length 8192 bytes
Reset phone ...
PM Field 308 Subfield 1 written OK
Reading SP Locks after Auto Write PM 308 ...
SP LOCK status:
Cable wrong codes counter: 0 wrong tries from max. 10 tries
Checking if model/version is supported for unlock ...
Please connect testpoints
Testpoints connected OK
Keep Testpoints connected until unlock finish!
Unlocking phone ...
Try number: 1
Sending SP code: #pw+012345678901234+7#
Response byte: 08
Try number: 2
Response byte: 08
Try number: 3
Response byte: 00
Reading again SP Locks ...
SP LOCK status:
    Block 1: OPEN    Type 5      Data: 23433F
    Block 2: OPEN    Type 5      Data: 23486F
Phone unlocked succesfull
Old 10-30-2007, 18:47   #17 (permalink)
Singh05's Avatar
Member: 69293
Thanks Meter: 19
100% working solution
thanks
Old 10-31-2007, 00:15   #18 (permalink)
Member: 20953
Thanks Meter: 94
very simple yet true! Tried , tested and true!
thanks for this idea
Old 10-31-2007, 06:49   #19 (permalink)
Member: 498516
Thanks Meter: 4
5200 V5.00
Wow It Really Works, Gr8 Solution.
Thnx
W.b.r
Old 10-31-2007, 07:09   #20 (permalink)
raezak's Avatar
Member: 260632
Thanks Meter: 639
Originally Posted by Arion123 View Post
Hi All,
Try to downgrade your phone (Nokia 5200 RM-174) 4.71 FW and
you will succeed.
no need to downgrade just follow this method
br
Old 10-31-2007, 08:06   #21 (permalink)
Member: 175216
Thanks Meter: 53
yes!! this solution is 100% working!!!!!!!!!
br!
Old 10-31-2007, 14:18   #22 (permalink)
Member: 163543
yeahhhhhh!
Thanks my friend it works perfect.
Type: RM-174
IMEI: 356435019987096
SP LOCK status:
Config Key: 2620700000000000
Block 1: CLOSED Type 5 Data: 262074
Block 2: CLOSED Type 5 Data: 262075
Reset phone ...
Autobackup file:
RM-174_356435019987096_Locked_Keycnt_0_Fbuscnt_10__V_ 05.00_27-04-07_RM-174_(c)_Nokia..bin
already exist
Finded backup file: RM-174_356435019987096_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-174_(c)_Nokia..bin
Reset phone ...
SP LOCK status:
Unlocking phone ...
Try number: 1
Response byte: 08
Try number: 2
Response byte: 00
SP LOCK status:
Block 1: OPEN Type 5 Data: 262074
Block 2: OPEN Type 5 Data: 262075
Old 11-03-2007, 16:53   #23 (permalink)
TATARIN's Avatar
Member: 67632
Thanks Meter: 37
Thanks, this is greates solution. 100% working. Tested on 6151. Because i have the same problem.
Old 11-03-2007, 21:24   #24 (permalink)
Member: 2461
Thanks Meter: 22
Many Thanks ,for this info .... I had an n73 that wouldnt unlock ..? tried about 10 times , then tried without the gnd and it unlocked first time
lol . I didnt loose $70
B.Rgds
John...
Old 11-06-2007, 13:57   #25 (permalink)
Member: 445380
Thanks Meter: 6
I perfectly unlocked a 5200 v. 5.00, but there's one here version 4.72, can't be unlocked do u guys know wich cable do i use to flash it on pkeybox?
Thanks all!
Old 11-06-2007, 15:13   #26 (permalink)
Member: 208759
Thanks Meter: 6
two post, sorry !
hatali
Old 11-06-2007, 15:17   #27 (permalink)
Member: 208759
Thanks Meter: 6
ok 100% with 5200 V5.00
Type: RM-174
IMEI:353641013076165
SP LOCK status:
IMEI: 353641013076165
SP LOCK status:
    Config Key: 4402000000000000
    Block 1: CLOSED  Type 5      Data: 44020F
    Block 2: CLOSED  Type 5      Data: 44020F
Reset phone ...
Autobackup file:
already exist
Reset phone ...
SP LOCK status:
Unlocking phone ...
Try number: 1
Response byte: 00
SP LOCK status:
    Block 1: OPEN    Type 5      Data: 44020F
    Block 2: OPEN    Type 5      Data: 44020F
Old 11-06-2007, 15:22   #28 (permalink)
Member: 336741
Thanks Meter: 152
nice info sir,...thanks for sharing i will try that one...great...
Old 11-07-2007, 12:29   #29 (permalink)
telefan21's Avatar
Member: 269824
Thanks Meter: 17
this solution no work for me.
I have two 5200 v5 and i try with GND and without GND and nothing ...
I try many times and nothing phone is locked.
I don't know why...?
Old 11-07-2007, 13:31   #30 (permalink)
Member: 5653
Thanks Meter: 6
Not working for me either.
5200 uk orange v5.00 ATD chip.
Tested on 3 units - none unlocked.
6300 version 5.00 Unlocked by Thomas Pkey FREEEEE boy_muslim BB5 No TP By Jafsupport 10 09-25-2009 02:31
Nokia 7373 version 5.00 unlock? mobile_2003 MT-BOX 3 02-29-2008 14:16
problem unlocking 5300 sw version 5.00 preshaust J.A.F. Plus 25 12-23-2007 11:45
Problem Unlocking 5200 Version 5.00 Black Mansoor UID - Box 7 11-02-2007 05:05
Page generated in 0.21472 seconds with 9 queries
