Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5BOX Products > BB5BOX
Old 12-13-2007, 16:20   #46 (permalink)
waleed2's Avatar
Member: 85387
Thanks Meter: 78
good yes its working tested thanks
Old 12-13-2007, 16:26   #47 (permalink)
Member: 146308
Thanks Meter: 30
just tested,work fine here,v5.00 orange from france
Old 12-13-2007, 17:05   #48 (permalink)
Member: 421331
Thanks Meter: 30
jaime17sv please you did it with the ground connected??? i have one piece similar like you posted with chipset atd with 13 block closed ...but i can't unlocked it until now
Old 12-13-2007, 23:52   #49 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
no gnd clip worked for me too after couple tries for v5.00 atd, tnx
Old 12-14-2007, 01:38   #50 (permalink)
Member: 421331
Thanks Meter: 30
I am confused today I unlocked 2 nokia 5200 RM-174 with chip atd and version 3.92 at the first time but I could see that both have only two types blocked and the unlockeable 5200 rm-174 with chip atd and version 3.92 have 13 types blocked, what is the difference? is for that the 5200 atd with 13 types of blocked is hard to unlock??..thanx
Old 12-14-2007, 15:03   #51 (permalink)
Member: 274408
Thanks Meter: 2
Connecting to BB5 Box ...
Searching for phone ...
Phone found on FBUS interface
Reading phone info ...
Type: RM-174
Version: V_05.00_27-04-07_RM-174_(c)_Nokia.
IMEI: 353931017701714
SP LOCK status:
Config Key: 7340400023927779
Block 1: CLOSED Type 5 Data: 73404F
Block 2: CLOSED Type 5 Data: 74000F
Block 3: CLOSED Type 5 Data: 732123
Block 4: CLOSED Type 5 Data: 71606F
Block 5: CLOSED Type 5 Data: 21407F
Block 6: CLOSED Type 5 Data: 21402F
Block 7: CLOSED Type 5 Data: 73002F
Block 8: CLOSED Type 5 Data: 72207F
Block 9: CLOSED Type 5 Data: 74807F
Block 10: CLOSED Type 5 Data: 33403F
Block 11: CLOSED Type 5 Data: 70403F
Block 12: CLOSED Type 5 Data: 70604F
Block 13: CLOSED Type 5 Data: 71030F
Block 14: CLOSED Type 5 Data: 71402F
Keyboard wrong codes counter: 0 wrong tries from max. 3 tries
Cable wrong codes counter: 2 wrong tries from max. 10 tries
Set Full Factory Defaults ...
Reset phone ...
Reset phone in TEST mode ...
Full Factory Defaults set OK
Create autobackup of PM 308
Reading PM Field 308 Subfield 1 with length 8192 bytes
Saving autobackup to file: RM-174_353931017701714_Locked_Keycnt_0_Fbuscnt_2__V_0 5.00_27-04-07_RM-174_(c)_Nokia..bin
Auto Write PM 308 procedure started
Searching for backup file with lowest FBUS count ...
Finded backup file: RM-174_353931017701714_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-174_(c)_Nokia..bin
Writting PM Field 308 Subfield 1 with length 8192 bytes
Reset phone ...
PM Field 308 Subfield 1 written OK
Reading SP Locks after Auto Write PM 308 ...
SP LOCK status:
Cable wrong codes counter: 0 wrong tries from max. 10 tries
Checking if model/version is supported for unlock ...
Please connect testpoints
Testpoints connected OK
Keep Testpoints connected until unlock finish!
Unlocking phone ...
Delaying unlock procedure with 4000 miliseconds
Try number: 1
Sending SP code: #pw+012345678901234+7#
Response byte: 08
Try number: 2
Response byte: 55
Try number: 3
Response byte: 55
Try number: 4
Response byte: 55
Try number: 5
Response byte: 55
Try number: 6
Response byte: 55
Try number: 7
Response byte: 55
Try number: 8
Response byte: 55
Try number: 9
Response byte: 55
Try number: 10
Response byte: 55
Unlock fail. Please try again.
helpl ???? new box bb5
Old 12-14-2007, 17:28   #52 (permalink)
boucettay's Avatar
Member: 148814
Sonork: 100.1576882
Thanks Meter: 5,013
who said that bb5 box is the best is wrong
that's why they said, new boxes will have more stability on dc and gave shema to modify box
till now i killed 4 phones and just unlocked 2
don't kkow why, but i'm sure tp was correct
5200 is easy tp and is dead with the first try
need new upgrade of v028, many pb
think there was less prob with v26 of this box
if this take time, think have to buy mt box
Old 12-14-2007, 18:40   #53 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
did not kill any bb5 yet and v28 works fine for me.
Old 12-16-2007, 23:01   #54 (permalink)
Member: 281005
Thanks Meter: 2
i have nkia 5200 black, after many try with connecting grnd, unlocking failed.
but without grnd unlock secessful.
now i have new problem 'the handset can not detect the simcard when i put any simcard in,
i got *** start up phone without SIM card?** it looks like there is no sim in the phone. i am sure that i put the sim in the right way and right position.
any idea whats wrong? please.
Old 12-17-2007, 05:23   #55 (permalink)
Crazy Poster
Member: 164480
Sonork: 1650120
Originally Posted by mughalG View Post
Well, most of my friend will be thinking whta magic I have done to unlock 5200 sw 5.00 .... BB5Box software always says Response Byte :08 ...
Nothing special i did not connected GND with PCB at all and set unlocked sucessfull
Yes yet simple.... plz try and let me know
I will try on other models which say Response Byte 08 even TP is ok and let u know ...
BR MughalG
sorry man what is pcb ? help me plz
Old 12-17-2007, 22:06   #56 (permalink)
Member: 428252
Thanks Meter: 21
big thanks from germany for this info its work 100%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
Old 12-18-2007, 13:59   #57 (permalink)
Member: 204319
Sonork: 100.1581770
Thanks Meter: 18
my nokia unlock no ground connected chip ATD
------ Operation: UNLOCK Date: 18-12-2007 Time: 13:06:14 -------
Type: RM-174
IMEI: 357672012408667
SP LOCK status:
Config Key: 2720100000000000
Block 1: CLOSED Type 5 Data: 27201F
Reset phone ...
Skip autobackup of PM 308
Autobackup file:
RM-174_357672012408667_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-174_(c)_Nokia..bin
already exist
Unlocking phone ...
Try number: 1
Response byte: 08
Try number: 2
Response byte: 08
Try number: 3
Response byte: 08
Try number: 4
Response byte: 08
Try number: 5
Response byte: 08
Try number: 6
Response byte: 08
Try number: 7
Response byte: 00
Reading again SP Locks ...
SP LOCK status:
Block 1: OPEN Type 5 Data: 27201F
Phone unlocked succesfull
Old 12-20-2007, 14:28   #58 (permalink)
Patrick's Avatar
Member: 100436
Thanks Meter: 57
BR MughalG
Thank you
BR's
Patrick
Type: RM-174
IMEI: 357672018xxxxxx
SP LOCK status:
Cable wrong codes counter: 10 wrong tries from max. 10 tries
Autobackup file:
RM-174_357672018xxxxxx_Locked_Keycnt_0_Fbuscnt_10__V_ 05.00_27-04-07_RM-174_(c)_Nokia..bin
already exist
Finded backup file: RM-174_357672018xxxxxx_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-174_(c)_Nokia..bin
Reset phone ...
SP LOCK status:
Unlocking phone ...
Try number: 1
Response byte: 00
SP LOCK status:
Old 12-20-2007, 15:48   #59 (permalink)
Member: 289307
Thanks Meter: 44
this solution its with j a f box or with bb5 box please help
6300 version 5.00 Unlocked by Thomas Pkey FREEEEE boy_muslim BB5 No TP By Jafsupport 10 09-25-2009 02:31
Nokia 7373 version 5.00 unlock? mobile_2003 MT-BOX 3 02-29-2008 14:16
problem unlocking 5300 sw version 5.00 preshaust J.A.F. Plus 25 12-23-2007 11:45
Problem Unlocking 5200 Version 5.00 Black Mansoor UID - Box 7 11-02-2007 05:05
Page generated in 0.22317 seconds with 9 queries
