10-09-2007, 19:06 | #1 (permalink) |
No Life Poster Join Date: Aug 2002 Location: Croatia Age: 48
Member: 14602 Status: Offline Thanks Meter: 18 | 5200 unlock problem Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-174 Version: V_05.00_27-04-07_RM-174_(c)_Nokia. IMEI: 357672013646174 SP LOCK status: Config Key: 2280300000000000 Block 1: CLOSED Type 5 Data: 22803F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-174_357672013646174_Locked_Keycnt_0_Fbuscnt_10__V_ 05.00_27-04-07_RM-174_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-174_357672013646174_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-174_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2280300000000000 Block 1: CLOSED Type 5 Data: 22803F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. anybody succesfuly unlock this phone? |
10-09-2007, 20:15 | #4 (permalink) |
Freak Poster Join Date: Dec 2004
Member: 101818 Status: Offline Thanks Meter: 2 | Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-174 Version: V_03.92_13-10-06_RM-174_(c)_Nokia. IMEI: 355537011264274 SP LOCK status: Config Key: 2340000300000000 Block 1: CLOSED Type 5 Data: 23410F Block 2: CLOSED Type 5 Data: 23410F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-174_355537011264274_Locked_Keycnt_0_Fbuscnt_0__V_0 3.92_13-10-06_RM-174_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-174_355537011264274_Locked_Keycnt_0_Fbuscnt_0__V_0 3.92_13-10-06_RM-174_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2340000300000000 Block 1: CLOSED Type 5 Data: 23410F Block 2: CLOSED Type 5 Data: 23410F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2340000300000000 Block 1: OPEN Type 5 Data: 23410F Block 2: OPEN Type 5 Data: 23410F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull --------------------------------------------------------------------------------- |
10-09-2007, 22:56 | #6 (permalink) |
Crazy Poster Join Date: Aug 2006
Member: 334231 Status: Offline Thanks Meter: 0 | If you downgrade BB5 phones they will be dead. You can flash the same version over it and perhaps it works. first i had the same problem. After flashing the unlock was successfull :-) |
10-10-2007, 10:05 | #7 (permalink) | |
Freak Poster Join Date: May 2004 Location: EU Age: 40
Member: 67146 Status: Offline Thanks Meter: 0 | Quote:
REALY?? Not all BB5 are allowed to downgrade software, but 5200 and many others are !! mmanduri using JAFF You have only to mark "donwgrade" option and choose flashfiles, next enter FLASH, phone will be "life" | |
10-10-2007, 12:15 | #8 (permalink) | |
Freak Poster Join Date: Aug 2001 Location: UK Age: 48
Member: 5653 Status: Offline Thanks Meter: 6 | Quote:
5200 on uk orange v5 ATD chip dont allow me to downgrade - phone blinks nokia. Had to upgrade using dead USB in jaf to get it working again. Was still not able to unlock as well after. | |
10-11-2007, 11:28 | #12 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Hungary,Deb Age: 58
Member: 10826 Status: Offline Thanks Meter: 19 | 5200 v5.00 ATD chip ! Allways unlock fail problem v0.2.5 (not repaired soft !) Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-174 Version: V_05.00_27-04-07_RM-174_(c)_Nokia. IMEI: 35767201365XXXX SP LOCK status: Config Key: 2160100000000000 Block 1: CLOSED Type 5 Data: 21601F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-174_35767201365XXXX_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-174_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-174_35767201365XXXX_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-174_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2160100000000000 Block 1: CLOSED Type 5 Data: 21601F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. Bakl |
5200 unlocking problem | randr | MT-BOX | 8 | 01-10-2008 15:36 |
5200 unlocking problem | crowys | BB5BOX | 2 | 10-24-2007 18:03 |
5200 unlock problem | Bult | UID - Box | 4 | 10-02-2007 00:27 |
5200 Unlock Problem | shami | MT-BOX | 58 | 09-25-2007 14:15 |
5200 Unlock Problem.... | shami | MT-BOX | 1 | 09-21-2007 09:55 |
