11-23-2007, 22:37 | #1 (permalink) |
Product Manager Join Date: Apr 2007
Member: 488825 Status: Offline Thanks Meter: 365 | 5300b not unlocked Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. Please help me, what should i do, ive tryed several times but allways get this error. thanks BR |
11-23-2007, 22:50 | #2 (permalink) | |
Freak Poster Join Date: May 2006
Member: 279120 Status: Offline Thanks Meter: 14 | Quote:
11-23-2007, 23:09 | #3 (permalink) |
Member: 488825 Status: Offline Thanks Meter: 365 | i did that and not working yet bro, here is log without connecting tp: Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_04.51_11-01-07_RM-146_(c)_Nokia. IMEI: 354********** SP LOCK status: Config Key: 3102000000000000 Block 1: CLOSED Type 5 Data: 310160 Block 2: CLOSED Type 5 Data: 310200 Block 3: CLOSED Type 5 Data: 310210 Block 4: CLOSED Type 5 Data: 310220 Block 5: CLOSED Type 5 Data: 310230 Block 6: CLOSED Type 5 Data: 310240 Block 7: CLOSED Type 5 Data: 310250 Block 8: CLOSED Type 5 Data: 310260 Block 9: CLOSED Type 5 Data: 310270 Block 10: CLOSED Type 5 Data: 310300 Block 11: CLOSED Type 5 Data: 310310 Block 12: CLOSED Type 5 Data: 310490 Block 13: CLOSED Type 5 Data: 310530 Block 14: CLOSED Type 5 Data: 310580 Block 15: CLOSED Type 5 Data: 310590 Block 16: CLOSED Type 5 Data: 310640 Block 17: CLOSED Type 5 Data: 310660 Block 18: CLOSED Type 5 Data: 310800 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: UNLOCK Date: 23-11-2007 Time: 16:12:01 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_04.51_11-01-07_RM-146_(c)_Nokia. IMEI: 3548*********** SP LOCK status: Config Key: 3102000000000000 Block 1: CLOSED Type 5 Data: 310160 Block 2: CLOSED Type 5 Data: 310200 Block 3: CLOSED Type 5 Data: 310210 Block 4: CLOSED Type 5 Data: 310220 Block 5: CLOSED Type 5 Data: 310230 Block 6: CLOSED Type 5 Data: 310240 Block 7: CLOSED Type 5 Data: 310250 Block 8: CLOSED Type 5 Data: 310260 Block 9: CLOSED Type 5 Data: 310270 Block 10: CLOSED Type 5 Data: 310300 Block 11: CLOSED Type 5 Data: 310310 Block 12: CLOSED Type 5 Data: 310490 Block 13: CLOSED Type 5 Data: 310530 Block 14: CLOSED Type 5 Data: 310580 Block 15: CLOSED Type 5 Data: 310590 Block 16: CLOSED Type 5 Data: 310640 Block 17: CLOSED Type 5 Data: 310660 Block 18: CLOSED Type 5 Data: 310800 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-146_354823010610217_Locked_Keycnt_0_Fbuscnt_0__V_0 4.51_11-01-07_RM-146_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-146_354823010610217_Locked_Keycnt_0_Fbuscnt_0__V_0 4.51_11-01-07_RM-146_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 3102000000000000 Block 1: CLOSED Type 5 Data: 310160 Block 2: CLOSED Type 5 Data: 310200 Block 3: CLOSED Type 5 Data: 310210 Block 4: CLOSED Type 5 Data: 310220 Block 5: CLOSED Type 5 Data: 310230 Block 6: CLOSED Type 5 Data: 310240 Block 7: CLOSED Type 5 Data: 310250 Block 8: CLOSED Type 5 Data: 310260 Block 9: CLOSED Type 5 Data: 310270 Block 10: CLOSED Type 5 Data: 310300 Block 11: CLOSED Type 5 Data: 310310 Block 12: CLOSED Type 5 Data: 310490 Block 13: CLOSED Type 5 Data: 310530 Block 14: CLOSED Type 5 Data: 310580 Block 15: CLOSED Type 5 Data: 310590 Block 16: CLOSED Type 5 Data: 310640 Block 17: CLOSED Type 5 Data: 310660 Block 18: CLOSED Type 5 Data: 310800 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. |
11-23-2007, 23:53 | #5 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Where money is made Age: 33
Member: 390642 Status: Offline Sonork: 100.1573430 Thanks Meter: 2,476 | I thinks its a TP problem make sure u are doing ok TP and conect GND where the picture indicates also try to downgrado to verison 03.92 i have done a lot with this version with out problems BR, Tito Millo |
5300b not unlock.... Error. Something wrong, - Maybe you try to unlock BB5+ phone ? | alasdro | JAF No Tp Unlocker by Cinek | 2 | 03-20-2009 22:15 |
5300b not unlocked | bimes | Universalbox | 6 | 11-24-2008 16:37 |
5300b not unlock with vspec | kalpeshoza | J.A.F. V-SPEC | 9 | 03-05-2008 18:01 |
Another 5300b v5.10 Not Unlocked | gsmdoctorca | MT-BOX | 5 | 11-30-2007 10:48 |
5300b not unlocking | Zukison14 | MT-BOX | 3 | 11-09-2007 11:51 |
