Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5BOX Products > BB5BOX
Old 11-03-2007, 17:44   #1 (permalink)
Member: 110102
Sonork: 100.1580399
Thanks Meter: 1,139
5300b unlocking problem due to someone upgrade the phone
Hi,
whenever i want to donwngrade any other version phone gets dead. only use same version phone is on.pls suggest me.
owering the phone...
Reading...
MCU SW version: V 05.02
05-06-07
RM-146
(c) Nokia.
HW version: 3001
PCI version:
RFIC version:  17211721
DSP version:  pb06w14v51
PPM version: V 05.02
05-06-07
RM-146
(c) Nokia.
NTM
Retu version: 32
Tahvo version: 53
Production serial number: RNB943916
Product code: 0515134
Module code: 0203052
Basic production code: 0530539
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 352732018924276
IMEI spare to net: 3A 25 37 02 81 29 24 07
IMEI SV to net: 33 25 37 02 81 29 24 17 F0
LOCK STATUS:
CONFIG KEY: 3027200000000000
Provider: Rogers AT&T Wireless;Canada
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: CLOSED -> Lock Data: 302720
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-146.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code: 0515134
No ini files found...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Done!
i want to unlock the phone
Wbr
[email protected]
09815177706
Old 11-03-2007, 18:07   #2 (permalink)
japunlock's Avatar
Member: 87396
Thanks Meter: 64
and flashing process log?
maybew ticking downgrade in flash options in jaf
i have successfully downgraded that version of 5300b to 3.92 via usb flashing
Old 11-03-2007, 18:41   #3 (permalink)
Member: 110102
Sonork: 100.1580399
Thanks Meter: 1,139
thanks a lot for reply
i hv downgrade a lot of with jaf & alwayse use tick at downgrade option.
5300b unlocking problem with bb5-box sukhdeep Nokia Base Band 5 ( BB-5 ) 4 05-01-2008 16:14
Small problem with the jigs to power up the phone .... Burnt Cobba SagMaster Team OLD Products 3 07-16-2004 00:02
problem to power up the phone without charger ZetMen Nokia Hardware & Hardware Repair 9 12-09-2003 19:43
T65 freezing when selecting a number to call, from the phone book. doctormike Sony Ericsson 0 07-18-2003 11:06
Sewon SG2200E Flash modding needed for new langs to put in the phone??? AE177 Various 0 06-30-2003 14:38
Page generated in 0.16944 seconds with 9 queries
