10-14-2007, 14:00 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: repair shop Age: 44
Member: 181825 Status: Offline Thanks Meter: 199 | n80 unlocking error Phone found on FBUS interface Reading phone info ... Type: RM-92 Version: V_05wk33v33.1_22-06-06_RM-92_(c)_Nokia. IMEI: 358361004449736 SP LOCK status: Config Key: 2341500000000000 Block 1: CLOSED Type 5 Data: 23415F Block 2: CLOSED Type 5 Data: 23415F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-92_358361004449736_Locked_Keycnt_0_Fbuscnt_0__V_05 wk33v33.1_22-06-06_RM-92_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. |
N80 unlock error!! | YasinŽ | Universalbox | 5 | 06-16-2008 20:55 |
n80 unlock error | ryaz1993. | Universalbox | 1 | 04-14-2008 11:33 |
N80.....unlock..error | damabib | MT-BOX | 3 | 12-12-2007 15:07 |
