09-26-2007, 09:47 | #1 (permalink) |
Freak Poster Join Date: Nov 2004 Location: romania Age: 43
Member: 91963 Status: Offline Thanks Meter: 34 | 6280 problem Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... ERROR: 11160001 ERROR: 30020061 where is th problem?? |
09-26-2007, 19:23 | #5 (permalink) |
Freak Poster Join Date: Jan 2002 Location: GipsylanD :D
Member: 8490 Status: Offline Thanks Meter: 27 | same problem with 6280 and is not from gnd...i have MT-PRO,UID and BB5Box and a lot of experience in BB5 unlocking.Only BB5Box give this error.i unlocked this phone with another box.with 3.81 and 4.92 i have this errors,but with 6.43 the box try to enter the code 10 times and 'phone is not unlocked'...strange. it's the first phone with BB5Box but i will try with another one and i will post the results. BR, XCHRIS |
09-30-2007, 14:14 | #6 (permalink) |
Freak Poster Join Date: Feb 2006 Location: MX-KEY is the BEST NOKIA TOOL
Member: 231588 Status: Offline Thanks Meter: 4 | @BB5box.org i have the same problem in 6680, i did what is in the picture, but it seems i've no luck at all! what possible solution? pls do make support for n71 phones! goodluck bb5unlocker team, more power |
09-30-2007, 15:44 | #7 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433756 Status: Offline Thanks Meter: 18 | me too brother, can unlock a 6280 at all. anyway, i will try to post a video of where i touch tp when unlock. i know its good but still can't. i alerady change 3 firmware version also. |
09-30-2007, 16:10 | #9 (permalink) | |
Freak Poster Join Date: Jul 2007 Location: 'round the world
Member: 561120 Status: Offline Thanks Meter: 5 | This errors is because phone gets out from TEST MODE TOO EARLY. I guess you didn't use power supply to supply the box. Try to use a power supply as requested in the sticky thread. Also other alternative solution is to prepare everything and connect the TP cable to box only in the last minute ... power the phone and unlock fast ... like 20 seconds. ( meaning have to make testpoints fast or ask someone to help you ) ( this is the solution in case you don't want to use aditional power supply and make the requested modifications to box ) Quote:
09-30-2007, 17:44 | #10 (permalink) | |
No Life Poster Join Date: Dec 2005
Member: 213638 Status: Offline Thanks Meter: 77 | Quote:
@newforgsm are you sure man?? | |
09-30-2007, 19:37 | #12 (permalink) |
Member: 91963 Status: Offline Thanks Meter: 34 | for me problem was the cable(because i want to large the tp adapters) now the problem is solved and i can unlock phones with no problem.and i give an advice !!! don't modify original cable !!! |
6280 problem | KOBOL | MT-BOX | 4 | 05-19-2006 17:22 |
6280 - problem after full flash | smootny | MT-BOX | 2 | 05-10-2006 15:29 |
6280 Problem | pgtl | Twisterflasher | 3 | 04-03-2006 14:45 |
