Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2001 Location: Sun Age: 44
Member: 4021 Status: Offline Thanks Meter: 781 | 6131 unlocking problem... please check. thanks! Phone found on FBUS interface Reading phone info ... Type: RM-115 Version: V_05.50_20-09-06_RM-115_(c)_Nokia. IMEI: 359390003414374 SP LOCK status: Block 1: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-115_359390003414374_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_20-09-06_RM-115_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 10 Sending SP code: #pw+012345678901234+7# tried with other box... but still no luck! |
![]() | #2 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2007 Location: 'round the world
Member: 561120 Status: Offline Thanks Meter: 5 | IT looks like SP Data is corrupted! Try to write write to phone initial backup! And check with flasher software if SP area is ok! You should try to make RPL calculation for this phone ! |
![]() | #3 (permalink) |
Banned ![]() ![]() ![]() ![]() Join Date: Jul 2005 Location: P.R.China Age: 39
Member: 162387 Status: Offline Sonork: 100.86669 Thanks Meter: 457 | yes, possible Config Key : FFFFFFFFFFF you will notice the Data: 00101F. use flasher defice to check info. br www.gsm-traders.com |
v3 Edge Unlocking Problem Please check all | G$m | MSS Box II | 4 | 04-24-2012 21:30 |
6131 keypad problem! Please help!!!!!! | Bloodware | Nokia Hardware & Hardware Repair | 6 | 07-09-2011 10:09 |
m120 unlocking problem... please check | ryumahon | Z3X-Team Products | 1 | 03-02-2010 06:04 |
z750 read infor problem , please advise! thanks | Small_boy | Universalbox | 3 | 01-13-2009 09:50 |
6131 unlock problem please help !! | feritk | MT-BOX | 4 | 08-06-2007 20:38 |
