09-28-2007, 12:41 | #1 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Denmark Age: 55
Member: 18805 Status: Offline Thanks Meter: 27 | 6131 please connect testpoints? My first phone with Pop port cable Nokia 6131. Can easily read info, but no connection when trying to unlock. Only goes to this step, it must be cable failure but where? Have opened cable and it looks like all solderings is OK. Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-115 Version: V_05.50_20-09-06_RM-115_(c)_Nokia. IMEI: 355509011213668 SP LOCK status: Block 1: CLOSED Type 5 Data: 23820F Block 2: CLOSED Type 5 Data: 23830F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-115_355509011213668_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_20-09-06_RM-115_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints WBR Falck |
09-28-2007, 15:19 | #2 (permalink) |
Member: 18805 Status: Offline Thanks Meter: 27 | And solved, after measuring all cables ect. found bad soldering on swith in tp needle. Unlocked Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-115 Version: V_05.50_20-09-06_RM-115_(c)_Nokia. IMEI: 355509011213668 SP LOCK status: Block 1: OPEN Type 5 Data: 23820F Block 2: OPEN Type 5 Data: 23830F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries |
k 550! flash ic is pasted how to connect testpoint | k babu | DreamBox | 1 | 11-26-2009 17:48 |
Please connect testpoints | canny2 | BB5BOX | 8 | 02-21-2008 02:10 |
7373 after connect testpoint > PHONE LOST | lolozulu | BB5BOX | 4 | 12-07-2007 17:26 |
how to connect testpoints to 6280 phone? | tmunot | MT-BOX | 44 | 06-30-2007 10:39 |
connect testpoint and press button if ready... | SicilianBoy | DreamBox | 1 | 03-01-2006 19:29 |
