04-21-2008, 13:29 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Location: www.gsm-ir.com Age: 44
Member: 159351 Status: Offline Sonork: 100.1576976 Thanks Meter: 179 | 6233 cant unlock after 10 times try why??????????? Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-145 Version: V_04.54_01-08-06_RM-145_(c)_Nokia IMEI: 35972800******x SP LOCK status: Config Key: 2342000000000000 Block 1: CLOSED Type 5 Data: 23420F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 7 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-145_35972800******x_Locked_Keycnt_3_Fbuscnt_7__V_0 4.54_01-08-06_RM-145_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Please connect testpoints ERROR: 11140001 ERROR: Connection with phone was lost! Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-145 Version: V_04.54_01-08-06_RM-145_(c)_Nokia IMEI: 35972800****** SP LOCK status: Config Key: 2342000000000000 Block 1: CLOSED Type 5 Data: 23420F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 7 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-145_35972800******_Locked_Keycnt_3_Fbuscnt_7__V_04 .54_01-08-06_RM-145_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Delaying unlock procedure with 500 miliseconds Try unlocking using cable codes ... Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using cable codes fail. Reading again SP Locks ... ERROR: 11160001 ERROR: 30020111 |
04-21-2008, 15:57 | #3 (permalink) |
Freak Poster Join Date: Oct 2003 Location: Bolton Age: 44
Member: 41976 Status: Offline Thanks Meter: 33 | hello! try to connect ground close to tp. also make sure u dont short any pins while connecting. make sure connection at the bottom is clean good luck. |
04-22-2008, 20:19 | #5 (permalink) |
No Life Poster Join Date: Jan 2006 Location: JAMAICA Age: 46
Member: 220143 Status: Offline Thanks Meter: 108 | Need Help with counter reset Hi all, I have a 6233 that nees to be counter reset. I see on support that counter reset is supported for 6233 RM 145 v4.52. I tried it and got version not supported. I Upgraded flash to V4.91 which I also saw on support, yet it still says does not support for counter reset. Can anyone say wat I am doing wrong. Its a Spansion 6233 RM 145 currently V4.91? Should upgrade it further to 5.10 ? Thats the last one I see on the support list. Wat to do |
04-23-2008, 17:47 | #7 (permalink) |
Member: 220143 Status: Offline Thanks Meter: 108 | Thanks, but I am not even asked for connect TP yet. I just read the phone to reset counter and I get message saying not supported. And its just a 6233 RM145 now V04.91 25-9-06. Any further ideas anyone? |
04-23-2008, 18:51 | #8 (permalink) | |
Registered User Join Date: Feb 2006 Location: Ireland / Belarus
Member: 234917 Status: Offline Thanks Meter: 160 | Quote:
04-23-2008, 20:22 | #9 (permalink) |
Member: 220143 Status: Offline Thanks Meter: 108 | Well the strangest thing happend. I wrote back the PM 308 file that I had saved before I tried unlocking it. No counters are saying 0. But when I try to unlock again I am getting this error now.:-- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-145 Version: V_04.91_25-09-06_RM-145_(c)_Nokia IMEI: 359728002608878 SP LOCK status: Config Key: 2343000000000000 Block 1: CLOSED Type 5 Data: 23430F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-145_359728002608878_Locked_Keycnt_0_Fbuscnt_0__V_0 4.91_25-09-06_RM-145_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using cable codes fail. Reading again SP Locks ... ERROR: 11160001 ERROR: 30020111 Wat does this means............. |
04-24-2008, 06:57 | #10 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Harare, Zimbabwe/ South Africa Age: 44
Member: 46546 Status: Offline Sonork: 100.1577435 Thanks Meter: 85 | @beerfoote1 have u ever unlocked another one b4? u r touching wrong pin on rap, and yo phone is switching off thats why you r getting that error... |
04-24-2008, 17:05 | #11 (permalink) |
Member: 220143 Status: Offline Thanks Meter: 108 | You know you could be right. I was just lucky to touche the right ones when using JAF-VSPEC. Anyway I am happy that it is now unlocked. Thanks to all who helped. And yes this is my first 6233. I will now try 6280 |
n73 wotp unlock after several times with advaced - just want to try it@gopalhot@ | gopalhot | Nokia Hardware & Hardware Repair | 0 | 06-08-2009 12:47 |
Nokia 6233 shut down after some time | prihir | Nokia Base Band 5 ( BB-5 ) | 1 | 03-26-2009 09:25 |
6233 cant unlock | yalcin_g | MT-BOX | 3 | 12-26-2007 14:03 |
3510 unlock after 5 times wrong code | schreinic | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 10-14-2003 08:41 |
3650 can't unlock after 5 time wrong entered | Siemens man | WD2 & APE (Symbian Phones) | 2 | 09-18-2003 11:44 |
