6233 unlocking problem I have a 6233 that is supported and it said unsupported when I try to unlock it. See log: Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-145 Version: V_04.54_01-08-06_RM-145_(c)_Nokia IMEI: 352749015641976 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Model/version NOT supported for unlock. Please upgrade or downgrade! (Version: V_04.54_01-08-06_RM-145_(c)_Nokia) this is supported based on test point program BB5Box QuickGuide and testpoint Viewer. So whats wrong?:confused::confused::confused::confused::con fused: |
which one you are using 027exe use 026 exe and its ok.......... |
first just u need to update ur box with latest version ..... and then u can unlock it ..also it odel is supored use latest version 028 |
Thanks |
