12-06-2007, 23:39 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: -worldwide-
Member: 592460 Status: Offline Thanks Meter: 110 | once agian here is 100% working solution for all 6280 & 6288 SEC ETA and SPANSION http:///vbb/showthread.php?t=455432 upgrade to 6.43 use 128k then downgrade to 6.1 dont use 128k for SPANSION http:///vbb/showthread.php?t=462226 upgrade to 6.43 use 128k all working 10000000000000000000000000000% so if not working then you are wrong TP or GND problem. /Remember sometimes you must change GND location. In many case (mostly spansion) I use GND clip on vibrator if not work on battery gnd connector. Other times you must put to as in picture - but mostly works on GND battery connector or vibrator. so far ALL 6280 & 6288s unlocked 100's pieces all 100% working so SEC ETA and SPANSION supported. Thanks @ Raskal & BB5Box team |
12-08-2007, 17:44 | #7 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 51
Member: 172127 Status: Offline Thanks Meter: 15 | Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.81_09-05-06_RM-78_(c)_Nokia IMEI: 359382003970927 SP LOCK status: Config Key: 2341500000000000 Block 1: CLOSED Type 5 Data: 23415F Keyboard wrong codes counter: 1 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-78_359382003970927_Locked_Keycnt_1_Fbuscnt_0__V_03 .81_09-05-06_RM-78_(c)_Nokia.bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-78_359382003970927_Locked_Keycnt_1_Fbuscnt_0__V_03 .81_09-05-06_RM-78_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 4096 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2341500000000000 Block 1: CLOSED Type 5 Data: 23415F Keyboard wrong codes counter: 1 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2341500000000000 Block 1: OPEN Type 5 Data: 23415F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
12-09-2007, 10:30 | #11 (permalink) |
Freak Poster Join Date: Apr 2004 Age: 48
Member: 61809 Status: Offline Thanks Meter: 4 | Hi, For the SEC, I did not understand well, sorry are Italian and the English go not agree, I must first ugrade to 6.43 and after downgrade to 6.10? That is, I flashare through both versions? regards, bjmira |
12-09-2007, 11:09 | #12 (permalink) |
No Life Poster Join Date: Mar 2007 Location: TuNiSiA
Member: 462224 Status: Offline Sonork: 100.1586374 Thanks Meter: 103 | 6280 with SEC chip not take more than 1/5Hr (most of this time preparing phone), and no more than 2 or three tryies (due to shaking hands). how? flash phone via usb to version 6.43, clean TP area (for best connection with probs), enjoy unlocking. for the spasion, i still not recieve any phone with that chip |
12-19-2007, 16:47 | #14 (permalink) |
No Life Poster Join Date: Aug 2002 Location: Romania, The Bla Bla Country Age: 44
Member: 14279 Status: Offline Thanks Meter: 35 | i'm facing a verry strange problem on a 6.43 spansion. it does not recognize TP's. cable is ok, tested before and after with another 6280 ETA and with 7370. No cable problems, no box problems phone doesn't lose communication with box (remains in test mode permanent). simply "please conect TP". we've checked the tp's. there're not broken (there is resistance versus GND from both of flash pins). |
12-19-2007, 17:19 | #15 (permalink) |
Banned Join Date: Apr 2005 Age: 42
Member: 137474 Status: Offline Sonork: 100.109924 Thanks Meter: 471 | I unlock in 5 minuts 6280 with spanison without problem ony GND must be close rap. bye Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_05.92_07-09-06_RM-78_(c)_Nokia IMEI: 353949016611437 SP LOCK status: Config Key: 2600200000000000 Block 1: CLOSED Type 5 Data: 26002F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-78_353949016611437_Locked_Keycnt_0_Fbuscnt_0__V_05 .92_07-09-06_RM-78_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2600200000000000 Block 1: OPEN Type 5 Data: 26002F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
100% working solution for w550 5,8,0,menu & auto on | dreameye | Sony Ericsson Hardware Repair | 0 | 06-11-2009 12:46 |
For all ub user here is the usefull program for all | tsarkh | Universalbox | 4 | 09-23-2008 10:53 |
100% OK solution For all people has problem unlocking & flashing SONY Z5 | CHUIBOI | Sony | 26 | 08-15-2003 21:45 |
I'd like to buy 100% working solution for 8210 | beginer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-19-2000 23:46 |
100% working SoftwareS for all N3210 versionS | gsmhacker | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 12-20-1999 00:18 |
