12-16-2007, 11:46 | #1 (permalink) |
Freak Poster Join Date: Nov 2006 Location: hyderabad
Member: 390217 Status: Offline Thanks Meter: 20 | 6280 after few trys now is dead plz guide me what to do plese see log Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.43_30-03-07_RM-78_(c)_Nokia IMEI: 357603002909778 SP LOCK status: Config Key: 2229900093172790 Block 1: CLOSED Type 5 Data: 22299F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: UNLOCK Date: 16-12-2007 Time: 14:11:33 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.43_30-03-07_RM-78_(c)_Nokia IMEI: 357603002909778 SP LOCK status: Config Key: 2229900093172790 Block 1: CLOSED Type 5 Data: 22299F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-78_357603002909778_Locked_Keycnt_0_Fbuscnt_0__V_06 .43_30-03-07_RM-78_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock fail. Please try again. Operation: READ PHONE INFO Date: 16-12-2007 Time: 14:52:08 ------- Connecting to BB5 Box ... Searching for phone ... ERROR: Cannot detect phone on FBUS interface ------ Operation: READ PHONE INFO Date: 16-12-2007 Time: 14:52:20 ------- Connecting to BB5 Box ... Searching for phone ... ERROR: Cannot detect phone on FBUS interface |
12-16-2007, 12:09 | #2 (permalink) | |
Insane Poster Join Date: Mar 2004 Location: w.yorkshire Age: 52
Member: 57802 Status: Offline Thanks Meter: 4 | Quote:
12-16-2007, 12:29 | #3 (permalink) |
Junior Member Join Date: Dec 2007
Member: 651562 Status: Offline Thanks Meter: 0 | Hi bro, same thing happened to me as well. but don't worry. Using a good microscope inspect the pins you have touched. I'm sure 95% those are shorted. Use a good needle to apart those pins. should work after that. |
12-16-2007, 13:23 | #5 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | same problem here.after some tries phone is dead.i have checked tp's there is no damage on rap.all pins are intact.i have tried flashing but phone stops write error at 3%.please help if somebody knows how to repair this one |
12-19-2007, 13:37 | #6 (permalink) |
Member: 390217 Status: Offline Thanks Meter: 20 | 6280 tp is good no power on all my friends plese give me idea how can i do pwr on again full flashing also done with jaf see jaf log CMT Boot Data: Asic ID: 000000010000022600010006010C192101003000 Asic Mode ID: 00 Asic EM ID: 00000352 Asic Public ID: 18300002D3700054603718115334D8EF320505B8 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: D:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.15.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 0000FFFF -> Unknown flash chip CMT Flash Data: 00000000000000000000000000000000 CMT Loader: D:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.16.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready Done! Restarting phone...Done! |
12-19-2007, 14:57 | #7 (permalink) |
Member: 651562 Status: Offline Thanks Meter: 0 | CMT Boot Data: Asic ID: 000000010000022600010006010C192101003000 Asic Mode ID: 00 Asic EM ID: 00000352 Asic Public ID: 18300002D3700054603718115334D8EF320505B8 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: D:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.15.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 0000FFFF -> Unknown flash chip CMT Flash Data: 00000000000000000000000000000000 CMT Loader: D:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.16.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready Done! |
12-19-2007, 16:33 | #8 (permalink) |
Member: 220603 Status: Offline Thanks Meter: 1,164 | what about this one Changing mode...Done! Booting phone... CMT Boot Data: Asic ID: 000000010000022600010006010C192101003000 Asic Mode ID: 00 Asic EM ID: 00000352 Asic Public ID: 0E4000168D7C0054198AC50D02EEF150F35065BC HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: D:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.15.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 002F0001 -> AMD CMT Flash Data: 00000000000000000000000000000000 CMT Loader: D:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.16.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready Done! Restarting phone...Done! |
12-19-2007, 17:28 | #9 (permalink) |
Freak Poster Join Date: Oct 2007 Location: ALGERIA Age: 45
Member: 600493 Status: Offline Sonork: 0550106737 Thanks Meter: 39 | hi all if u 6280 is dead aftere trys u dont flash u phone check u pin of cpu if not domaged if not domager u plac u chargeur after 60 m u phone is revived , but not flashe u phone becaus is stoped in eras flash i have solved my phone with this method |
12-20-2007, 01:24 | #10 (permalink) | |
No Life Poster Join Date: Aug 2003 Location: Palestine
Member: 36394 Status: Offline Thanks Meter: 250 | Quote:
WBR | |
12-20-2007, 07:53 | #11 (permalink) |
Product Manager Join Date: Sep 2007
Member: 588059 Status: Offline Thanks Meter: 47 | Use a GOOD MICROSCOPE even when make "only" unlock on 6280 to avoid any damages !!!! And not use microscope only to check what you damaged when try to unlock 6280 without a GOOD MICROSCOPE (or unlock using some cheap magnifier)! As you can see, so easy to damage 6280 phones ... and there is chances to NOT SEE by visual inspection what exactly you damaged before (... when unlock without microscope or with cheap magnifier) |
12-20-2007, 21:44 | #13 (permalink) |
Registered User Join Date: Feb 2005 Location: Turkiye :islam
Member: 115596 Status: Offline Sonork: [email protected] Thanks Meter: 1,127 | Nokia 6280-6288 no problem UNLOCK good microscope then ok NO problem |
12-20-2007, 22:44 | #14 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: rochdale uk
Member: 396778 Status: Offline Thanks Meter: 155 | Quote:
after formate this phone now is dead | charletan | Infinity-Box | 5 | 03-10-2009 17:52 |
my x150x after unlock now is DEAD | cllins | Infinity-Box | 1 | 02-04-2009 20:14 |
after unlock my w180 now is dead | hans salim | Rocker Dongle (By Legija) | 2 | 09-05-2008 14:41 |
sagem 226 after unlock now is dead | MOBIFEMI | FuriousGold | 7 | 04-09-2008 20:46 |
L6 after full flash now is dead? | makkah mobile | Smart-Clip | 15 | 11-07-2007 10:50 |
